Weight of oil?
Kayaker120 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kayaker120 Quote  Post ReplyReply Direct Link To This Post Topic: Weight of oil?
    Posted: 01 Dec 2010 at 7:24am
HI! Getting ready for winter, what weight oil sould I use in my B? I usually go with a SAE 10. Would a blend be better, say 5w30? Oh yeah, snow plowing in Wisconsin.
Thanks!
Dan
Tricky Dickie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tricky Dickie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 8:15am
Use a multigrade like 10-30, or 10-40. That will do you fine!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 8:30am
10/30 would be my choice, a good high quality oil. 10/40 just does not have the lubricity of the other in additive package. Run it year round.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 10:29am
I've gone to using Mobil 1 Turbo Diesel 5w-40 oil in everything.  It is also rated for API SL and SM gas engine use.  It also has higher levels of Zinc and Phosphorous than most other oils available today.  With this oil, you just leave it in year around.
Here's a link to what's in the various Mobil 1 oils and what they're recommended for:  http://www.mobiloil.com/USA-English/MotorOil/Files/Mobil_1_Product_Guide.pdf
Edited by 427435 - 01 Dec 2010 at 10:30am
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 1:35pm
Are you just using it for the winter and changing in the spring?  If so, use a 0w-30 or 5w-30.  If you are not going to change the oil in the spring stick with 10w-30.  There is not such thing as an oil to thin below 32 degrees(multigrades that is)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 5:51pm
I put 0w-30 Mobil 1 in the CA so it is easy to start and gets lubrication to the rods ASAP since they are not pressure lubed. There is a tiny hole in the cam that registers with a hole in the rod cap. Takes some time to get oil to the rods.
Dave H M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H M Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 5:58pm
Wouldn't that depend on where/how it was stored?
