AC 7045 FUEL PROBLEM ONLY ON HILL |
Post Reply |
firecowallis
Orange Level Joined: 16 Mar 2012 Location: Helenville Wi Points: 464 |
Posted: 18 May 2016 at 6:42pm |
I have a allis 7045 that keeps dieing when going up hill. reacently changed the fuel filter in it primed the injector pump to get rid of any air bubbles nd now while pulling the disc whenever i turn uphill the tractor shuts off wont start unlet i go and pump the fuel line but then fires right up any suggestions? thanks in advanced
allis g 7045 200 wd45 wd45d c ca 6080 u
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
There may be something in the tank that when you go uphill it moves to cover the fuel line. Leon R Cmo
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7232 |
Low fuel level in the tank. Fill it right up and see how it works.
victoryallis
Orange Level Joined: 15 Apr 2010 Location: Ludington mi Points: 2865 |
I agree. One of our 6080's would surge a bit on corners. Ended up finding a bit of debris in the tank. |
MACK
1 or 2 fuel tanks? MACK
firecowallis
2 tanks half tank of fuel tractor rus great untill i go up hill and shuts down and loses prime get out and pumpthe push primer and will start right up till next round weak pump? i dont think so becouse what would the hill have to do with it going to cheack tank today but we filter all fuel driving me crazy
Orange Level Access Joined: 12 Sep 2009 Points: 19663 |
Try a new fuel tank fill cap. The vent might be plugged causing a vacuum in the tank.
LeonR2013
I've seen the fuel cap thing happen on KW's. Leon R CMO
MACK
Thanks(1)
Put a clear plastic hose from filter to inj pump
. Sounds like sucking air. When going up hill it takes more fuel, so it sucks more air. With the clear tube you can see the air. MACK
DSeries4
Debris in the fuel tank moves to cover the tank outlet when you go up hill? After 40 years, I would think those tanks could use a good cleaning.
Post Reply | |
