Generator for 271 |
WaltDevore
Joined: 03 Jan 2020 Location: IdahoSprings CO Points: 143 |
Topic: Generator for 271Posted: 01 Sep 2021 at 3:36pm |
Looking the motor generator on a 1951 Detroit 271 Allis Chalmers HD5. Thanks!
Joined: 11 Sep 2009 Location: illinois Points: 89968 |
Posted: 01 Sep 2021 at 4:35pm |
some good reading and ideas........
WaltDevore
Posted: 01 Sep 2021 at 9:09pm |
Thanks for the link. Good info!
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42191 |
Posted: 02 Sep 2021 at 11:13am |
Works well to replace generator with Delco 10SI alternator .
Using a single wire hookup it is all self contained and no external regulator is needed . |
WaltDevore
Posted: 02 Sep 2021 at 12:07pm |
Do you think the double belt pulley would mount to that shaft or does one go with a single belt.? Thank You.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4839 |
Posted: 03 Sep 2021 at 11:54am |
The double belt pully on mine fit the Delco alternator that I used. It has been some time since I messed with it, but the mounting was not hard. Mostly getting the tightener to fit.
Coke-in-MN
Posted: 06 Sep 2021 at 12:28am |
Pulley interchanges - only thing belt speed with large pulley means you need to rev the engine to get it to excite and charge first time .
I found a 2 belt pulley of a GMC truck alternator double groove that was steel (cast) then put in lathe and machined it to the wider belt size - it was a lot smaller diameter so dont have to do that step of high RPM to get it to charge . |
