Generator for 271
WaltDevore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Topic: Generator for 271
    Posted: 01 Sep 2021 at 3:36pm
Looking the motor generator on a 1951 Detroit 271 Allis Chalmers HD5.  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2021 at 4:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2021 at 9:09pm
Thanks for the link.  Good info!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2021 at 11:13am
Works well to replace generator with Delco 10SI alternator .
Using a single wire hookup it is all self contained and no external regulator is needed .
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2021 at 12:07pm
Do you think the double belt pulley would mount to that shaft or does one go with a single belt.?  Thank You.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2021 at 11:54am
The double belt pully on mine fit the Delco alternator that I used. It has been some time since I messed with it, but the mounting was not hard. Mostly getting the tightener to fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2021 at 12:28am
Pulley interchanges - only thing belt speed with large pulley means you need to rev the engine to get it to excite and charge first time .
 I found a 2 belt pulley of a GMC truck alternator double groove that was steel (cast) then put in lathe and machined it to the wider belt size - it was a lot smaller diameter so dont have to do that step of high RPM to get it to charge .
This page was generated in 0.217 seconds.
