Gear lube in frt pedestal
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Topic: Gear lube in frt pedestal
    Posted: 31 Dec 2011 at 9:44pm
I changed the seals in the front steering pedestal on my WD Allis. I am looking for the number weight of gear lube that is in there and where can I get some? I have been told that it may be number 250 weight but have not found it anywhere.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 10:10pm
85-140 will work just fine. You can get it by the quart at napa.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 10:12pm
I run John Deere corn head grease in mine. It's a flow-able grease that tends not to leak as bad.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 8:39am
I use straight 140 wt in my tractors (both steering gear boxes). Available from NAPA
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 11:24am
Chain saw bar oil in our old CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2012 at 8:16pm
If I use straight 140 weight lube in the front end will that leak out?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2012 at 8:47pm
That will depend on how worn things are. Whith new seals I would doubt it, but if the surfaces the seals seat on are not true you could still have some leakage.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2012 at 9:15pm
Lucas sells it but I don't know if they sell in anything other than gallons.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
