gaskit leak???
vinnied/s.d. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vinnied/s.d. Quote  Post ReplyReply Direct Link To This Post Topic: gaskit leak???
    Posted: 01 Aug 2016 at 2:01pm
I NEED TO FIND THE LEAK AROUND MY CARB. THERE WAS TALK ABOUT SPRAYING SOME THING AROUND IT THAT WOULD INDICATE THAT THERE WAS A LEAK WHEN THE MOTOR WAS RUNNING   WHAT IS ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2016 at 2:31pm
Please quit using all caps for anything.  All caps denotes you are YELLING.......
You can use WD-40 to spray with the little red tube.  If the motor changes running, that will show you where the carb/manifold is leaking.  HTH
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2016 at 2:34pm
I've heard of spraying starting fluid.
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 1:20am
A lot of people use carb and choke cleaner in a spray can, burns similar to fuel, and not nearly as destructive as ether.
sho-man1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote sho-man1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 10:17am
Use your little benzomatic propane torch, don't light the flame, just turn on the gas and move the nozzle around the carb. when the engine speeds up you found your leak. I like to hook a vacuum hose/tube to the tip, open the gas valve and spray around the intake and carb...
This page was generated in 0.180 seconds.
