G262/G230 Gasket set
Baldwinm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baldwinm Quote  Post ReplyReply Direct Link To This Post Topic: G262/G230 Gasket set
    Posted: 28 Dec 2016 at 2:59pm
Where can I get a full gasket set for a G-262? Diesel sets seem to be plentiful but gas sets are hard to come by without paying over 300. Can I get a diesel set and then just get a separate gas engine head gasket or are there other things different? Engine is a G-230 with a G-262 head
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 3:14pm
I needed one for a D 15 engine for a fork lift which is different than the tractor D 15 engine gasket set.  After calling my 4 AGCO dealers that usually can get most of these items and could not find a set, I went to my local NAPA and asked.  They ordered it in and the search was over.  So I guess I'm saying, try NAPA (ours is very friendly with these older engines so your NAPA my not have the same results).   Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baldwinm Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 3:28pm
Napa does have a full set but its for a diesel. They only have a head set for gas engines as long as head gasket is the only thing different ill just get both of those.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 7:48am
Try Minn-par parts, they have many hard to get AC parts if Norm Meinert can't get it.  815-238-4506
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baldwinm Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 7:24am
Any input on the diesel set vs gas sets?
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 8:25pm
Off the top of my head the only different gaskets would be the head and intake/exhaust manifold... The front cover or adapter plate may be different depending on application... Is the water pump on the block or head? You could also try www.agcopartsbooks.com and compare the gaskets on a D19 as it is the only tractor that used the G262 and the D262...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Baldwinm Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 11:30am
Adapter plate and front cover will be coming off my wd45 230 diesel engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2017 at 7:51pm
The inner gasket is probably the same between the D230 and the G262, but I doubt the outer gasket between the plate and the cover is the same. I'm not sure you can use the D230 adapter plate with the G262 governor without some modifications...
