G Mower Sickle Blade, Need Info
WCarp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WCarp Quote  Post ReplyReply Direct Link To This Post Topic: G Mower Sickle Blade, Need Info
    Posted: 07 Sep 2016 at 12:31am
I have what I believe is an AC G mower sickle blade that's been setting around for awhile that I would like to sell and was wondering if there are any experts out there that could confirm whether it is a G sickle mower blade or not? I downloaded photos of it.
Some measurements are: Ball measures 1 3/8" across, on hole to hole to side. Ball has 1/4" hole through it. Plate, ball is on measures 3 13/16" wide. Length 5' 4". Has 20 3" sections. Has 315540 on knifehead on top, 6" from ball.
Thanks.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 7:18am
If I recall all sickle blades were the same for all Allis Chalmers ball type blades.
If the size - 5' 6' 7' - was the same they were interchangeable.  Course the G only had a 5' blade.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote WCarp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 2:19pm
I called a tractor dealer and found indeed that it is a model G sickle blade. If a person puts a 70 in front of the number (which is common for the older parts) on the sickle head, the number is found.
So now I will try to sell it.
This page was generated in 0.045 seconds.
