G ground sprocket chain
Warren(Oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Topic: G ground sprocket chain
    Posted: 23 May 2012 at 6:11pm
I'll ask this again in case everyone is tired of the planter post...
Does anyone happen to know the chain size that fits the ground drive sprocket on the G tractors ?
I'm gonna try to rig up a side dresser, amoung everything thing else I'm trying to make for my G. Potato digger, weed wiper, side dresser, new planter mounts, on and on...
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 6:34pm
My parts books says the chain is part number 913857 and to use 115 links.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 7:23pm
Thanks Dusty. Is that number of links how many links is needed for a particular piece of equipment ? I just need to find the size of the links so I can get some. No telling how many I'll need since I'm trying to make this from scratch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 7:37pm
It's labeled as Duplex Hopper & Chain Drive.
PM me your e-mail me your e-mail address and I'll e-mail a scan.
Dusty
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:48pm
I think it is a #35 chain. I have some and can look for a # on it on Friday when I go to the farm. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 3:17am
Thanks, Dusty. I have a book with the first picture but not the other two.
Thanks Bob, #35 is a place to start ! I'll swing by TSC and get a few sections to try. Then I'll see if this old 3 point planter has sprockets that use the same size so hopefully I won't have to buy a new sprocket. I'm sure mounting bearings to the tractor frame will be fun, too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 5:35pm
Of course, TSC doesn't have any #35....
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 5:39pm
Warren, take your sprocket to your nearest bearing supply house and they can tell you exactly what chain you need, good luck !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 3:05am
If I get off work in time today, I'll run out to Cross and sons farm equipment here in Jackson, they'll have it. The sprocket is on the tractor, kind of a nuisance to take it off but I have another, bigger sprocket that has the same distance between the teeth that should do for sizing. Be lucky if the bearings get here before the middle of next week anyhow.
Of course, Cross and Sons had it. It's #32, got a 10 foot roll for a bit over $40. I'll never wear it out !
Dang Chinese chain ! You can practically tie a knot in it while it's laying flat !!! Brand new wore out !
Edited by Warren(Oh) - 04 Jun 2012 at 6:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 6:38pm
I got my 'side dresser' finished last Saturday. Looks like it should work, won't know till it's in the field.
Question : How much fertilizer should be put in the row, say, for sweetcorn ? What number (12-12-12) should I look for ? Nitrogen being higher for corn/cane.
What number for potatoes ? Taters don't need so much nitrogen, they need the other stuff. Growing up Dad only bought 12-12-12 but I see a lot of different numbers at Walmart of all places but it's for lawn care, has weed killer in it.
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 12:03am
Warren, I am interested in your plans for the potato digger? Herb
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 6:12am
Well, I don't have any plans drawn up, everything is in my head and has gone through a couple rethinks since I started it. I do have most everything built and awaiting final assembly. The digger head needs some whittling on the sides so the front wheels can be turned, someone made it to long toward the front...
I'll see if I can throw together a rough drawing and post it here.
I'm still waiting on a price for a left hand manual lift plow and lift assembly, Herb....
Edited by Warren(Oh) - 23 Sep 2012 at 1:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 6:48am
OK, I can't draw everything I've done so I'll post a couple actual pictures of what I have so far. Here's a rough drawing, though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 7:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 7:17am
Stupid thing will still only let me post two pix at a time !Angry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 7:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 8:32am
If you had hydraulic lift it would not be too hard to convert it to a split lift, for both right and left.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 8:40am
I actually know where there is both, one with manual, one with hydraulic and last I heard from him, they were for sale as a pair. I only need/want the left hand plow and manual lift assembly to go with one of the right hand ones I have, to be used, too. No more shows for me, local anyway. Maybe someday.
