G block sleeve possible
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: G block sleeve possible
    Posted: 26 Nov 2011 at 4:59pm
Ok, I have a good G block except for a 'pinhole' from one cylinder to the water jacket.
Has anyone had a sleeve installed before? My old Willys Superhurricane six had one done and every 'small engine' has them.
Wondered if practical cost wise ??
Seems a real shame to scrap as it's NOT cracked(first guy was wrong..)
Thanks
Jay
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 5:15pm
Where in the bore, like how far down is the pinhole and how big is it?  You may be able to repair it with a steel epoxy product.
 I had some severe pitting from water standing in two of the bores in my one of my 20-35 engines, about 1/2 way down the bore. An old engine builder advised me to clean the area really well and get rid of all traces of oil, then fill the areas with Devcon Plastic steel and let it set up for a few days. Clean it up and hone with a medium grit to level it off, then lightly hone the bores.
I have run this engine for 10 years now with no problem and after removing the heads and looking down the bores there is no evidence of the repair. The piston rings have polished the repaired area so it looks the same as the rest of the bore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 6:19pm
Jay, I have seen several G blocks that were sleeved. I think one that I have rebored was sleeved also. Professional job should be no problem. HTH Tracy Martin
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 9:35pm
sleeving is no big deal. i have a 427 ford engine that has a sleeve and know several people that have engines that have a sleeve .any compitent machine shop should be able to fix you up ...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 2:38pm
Hay...I found that Walt's tractors has sleeves ! $40 Man this 'internet thing' is kinda neat...though it took me 2 1/2 hours to find it !
Seems more than likely I can keep the block from going to China !!
This page was generated in 0.030 seconds.
