Full Flow oil.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: Full Flow oil.
    Posted: 21 Dec 2018 at 8:41pm
What year or at what ser # did the D17 go to the "Full Flow" oil system ?
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 8:48pm
SN 24,000 and up had full flow, mid 59 or so, black bar grill tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 10:25pm
Effective on G-226 engine s/n of 17-19978 and up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2018 at 9:47am
But over the years many mods happen so not unusual to find a full flow in an older one. Just look at system to identify when viewing tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2018 at 4:24pm
There was a point in time where the old style G-226 blocks were discontinued and the full-flow block was the only replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2018 at 11:22pm
My cousin has a 57 or 8 that has a full flow in it.Bought used of course so don't know the history.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2018 at 11:45pm
If the block doesn't have a s/n behind the carb, it was a new block from the parts dept.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2018 at 8:43am
When I worked at the Allis dealership the older mechanics told me that they converted several early D17 engines over to full flow.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2018 at 8:46am
I'd bet most of them had spun the center main bearing, ruining the block at the center main area. The factory change to full flow did two things: kept engine oil CLEAN and increased oil pressure because the oil pump speed was increased. Just changing the block to the full-flow style got you cleaner oil. To increase the oil pressure required a new camshaft and an oil pump driven gear on top.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2018 at 12:36pm
Would another reason to increase more volume to the larger diameter mains?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2018 at 3:52pm
The Engineers made a mistake in the early G-226 engines in my opinion. They provided engine oil 100% of the time to the rod bearings. This was to increase rod bearing life with the increased compression/power pressure and RPM's of the new engine.  On a W-201/W-226 the rod bearings were only oiled 1/6 or 1/3 of the time (don't remember which one). So, they soon found out that as the G-226 got some wear on the bearings(including cam brgs), they didn't carry any oil pressure. This was the reason for increasing the oil pump speed was to provide more volume (GPM's) to keep up with the demand of 100% rod bearing oiling. By the time they got to the Series 4 engine with the "Tufftrided" crankshaft journals, most of the time the crankshaft didn't even need to be reground at the first overhaul. Just slip in new main bearings (at -.001 under) and standard rod bearings and you were good to go. Now, if you had a Customer who was terrible on oil changes and regular maintenance, this might not be true.
Edited by DrAllis - 23 Dec 2018 at 3:56pm
