Fuel line fittings? |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10781 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Sep 2012 at 1:46pm |
What and where can you purchase the original type male tube and female carb and bowl fuel line fittings? Thanks Tracy Martin
Skyhighballoon(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Tracy - are they not standard brass flare fittings? We used off the shelf brass plumbing flare fittings and bent flared brake line to replace the fuel line on my D17 Series IV back in 2006 and it worked great. Looks original to me. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Mike, They are inverted flare fittings, but I can't remember what they are called. I have the outside female type now. Looking for a male internal type. Thanks Tracy
Butch(OH) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3842 |
Tracy the threads and flare are the same as used on U.S. brake lines,, at least he older ones I am used to. A double flare tool as used on the steel brake lines wil make for nice leakproof flares on the copper tube but a std tool will due. The modern made fittings such as the 90 pipe to tube fitting for the carburetor may not look like the originals depending on how old the equip is. NAPA used to have al manner ofsuch and if you still have a REAL hardware store around they will have both types of flare fittings and nuts.
Butch, Thanks for the info. Tracy Martin
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
I got them at NAPA also. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
GlenninPA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Tracy, the only trouble I have had is getting flares that have the 1/8 MIP end to tie into the sediment bowl or carb. You need to find someone who has a full line of flare/ 1/8 MIP fittings. Glenn
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
countryguy828 ![]() Bronze Level ![]() Joined: 11 Sep 2009 Location: Arcanum, Ohio Points: 129 |
I'd try McMaster Carr. I got aluminum 1/8 inch line and fittings from them for my CA and B. It's been several years ago though. Dave |
