Fuel line fittings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Fuel line fittings?
    Posted: 13 Sep 2012 at 1:46pm
What and where can you purchase the original type male tube and female carb and bowl fuel line fittings? Thanks Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 2:36pm
Tracy - are they not standard brass flare fittings?  We used off the shelf brass plumbing flare fittings and bent flared brake line to replace the fuel line on my D17 Series IV back in 2006 and it worked great.  Looks original to me.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 3:09pm
Mike, They are inverted flare fittings, but I can't remember what they are called. I have the outside female type now. Looking for a male internal type. Thanks Tracy
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 4:06pm
Tracy the threads and flare are the same as used on U.S. brake lines,, at least he older ones I am used to. A double flare tool as used on the steel brake  lines wil make for nice leakproof flares on the copper tube but a std tool will due. The modern made fittings such as the 90 pipe to tube fitting for the carburetor may not look like the originals depending on how old the equip is.  NAPA used to have al manner ofsuch and if you still have a REAL hardware store around they will have both types of flare fittings and nuts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 7:53pm
Butch, Thanks for the info. Tracy Martin
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 9:20pm
I got them at NAPA also. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 9:22pm
Tracy, the only trouble I have had is getting flares that have the 1/8 MIP end to tie into the sediment bowl or carb. You need to find someone who has a full line of flare/ 1/8 MIP fittings. Glenn
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 9:55pm
I'd try McMaster Carr. I got aluminum 1/8 inch line and fittings from them for my CA and B. It's been several years ago though.
Dave
