Front seal for B
steigerbro24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Topic: Front seal for B
    Posted: 11 Jan 2012 at 5:38pm
I want to replace the front seal on my B, do I need to take the radiator and the support off or is there an easier way. Also what do I need to take off to get the oil pan off. It looks like I need to take the front axle off.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 6:22pm
Some B's you can rotate the pan and it will slip out corner ways. Others you will need to move the front axle ahead about a half inch.
It would be easier to change the seal if you jack and block under the torque tube and remove all of the front along with the axle. That solves the pan problem.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 9:38pm
Like Dick said, you need to remove the front axle, the radiator and support and the crank pulley. You can pull the seal by drilling 2 holes in it and inserting sheet metal screws into the hole and pull on them to get it out. At that point, the only problem in removing the oil pan are the three bolts at the rear. They are a little tight to get at.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 5:36am
Don't spend a lot of time looking for that third bolt in the rear of the pan. It sure can seem like four trying to get them out though.  Three in front but only two at the rear that take small hands and fingers. (:^D
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 4:05pm
Thanks guys for the help we just got snow by me and I don't have a heated shop I need to wait for spring but the problem is solved
This page was generated in 0.110 seconds.
