Front Loader Mdl 9, Seal Leak Help...
dpehrson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpehrson Quote  Post ReplyReply Direct Link To This Post Topic: Front Loader Mdl 9, Seal Leak Help...
    Posted: 21 Jul 2012 at 12:52pm
I just sprung a large leak of hydrualic fluid coming from the packing end of my right loader ram. THis is a model 9 "tube" loader mounted on a 1955 WD45 tractor. Is there anybody out there that can help on what to do to repair this leak...I need to get back to work.
Thanks a million for any info...
Dave
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 11:01am
There are bolts that hold the packing in place.  Try tightening them down.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 11:04am
Seals are still available from AGCO, I got mine at Sandy Lake Imp 1-888-252-0656
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 11:37am
Baum Hydraulics may have the seal. www.baumhydraulics.com. down load the tractor seals section and search it.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpehrson Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 3:01pm
Thanks for the replies!! Much appreciated,
Before I read your replies, I ventured out on my own to solve the problem and discovered the bolts on the packing retaining collar were loose. After tightening, the leak was markedly reduced and I finished my work for the day. Looks like I'll be replacing the seals...
THanks a million!!
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpehrson Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 9:53pm
I sprung a leak again after lifting a 1000 # diesel engine...tightened the packing bolts a bit more and that fixed it. Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 10:13pm
There is no "seal" in there. It is a chevron packing and can be purchased at most any hydraulic supply house given the rod diameter, gland inside diameter and packing height. Costs about $10-$12 for one cylinder.
http://www.sealsales.com/packing/vpacking.html
If your rods are scratched up or galled, you'll play heck keeping the leaks down. Rust pits are heck on the packing also. This kind of packing needs a little bit of "weep" of fluid to keep them lubricated so over tightening can cause problems also.
Edited by CTuckerNWIL - 14 Aug 2012 at 10:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpehrson Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 10:18pm
Thanks CTuckerNWIL,
Your info is much appreciated!!
Dave
dannyraddatz View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 10:29pm
This may fill in some of the questions and answers, follow the link and hit slide show. The v packing rings are AC part #72000650 (packing)
Edited by dannyraddatz - 14 Aug 2012 at 10:38pm
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpehrson Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 10:58pm
Danny,
Score! Give that man a star! thanks a million for the extra detail on working this issue and resolving this topic.
Cheers,
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 9:08am
As always for all members please follow this link that is in my slide show as to the dangers hydraulic fluid can have on the human body.
Edited by dannyraddatz - 15 Aug 2012 at 9:09am
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpehrson Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2012 at 9:41am
Yes, I will take that seriously!! I recall learning of this danger when I was in the Air Force and we had to use high pressure hydraulics to jack-up very large aircraft.
Additionally, I learned by experience to never put my finger in front of a car wash spray nozzle at a mere 100 PSI...It sliced my finger like a razor...and then a bad infection made it much worse.
Thanks for the safety briefing!!
Dave
This page was generated in 0.176 seconds.
