Front Hyd Pump - Old B
Texas B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas B Quote  Post ReplyReply Direct Link To This Post Topic: Front Hyd Pump - Old B
    Posted: 26 Apr 2011 at 9:46am
Has anyone ever seen a dual set of pulleys put on the front of the front pulley and put a hyd pump on an older B?  The pulleys are brazed to the WP pulley - thinking I might be in real trouble on replacing front seal.
Texas B 39
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 11:53am
Yes I seen a power steering pump put on a b off of a car. he used it to lift his belly mount grader blade. Didn't look exactly as to how the setup worked but it had it's own belt
wigtrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wigtrain Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 3:21pm
All three of my B's are set up this way. No problem with the front seal as when the standard pulley comes off so does the hyd pump pulley.  Gives me live hyd for any implements I use. Did need to cut a notch in the radiator support bracket for belt clearence but the correct police don't get to look at my tractors. Works fine for me. Cut the center out of the pulley being brazed on so that the hand crank will still work and all should be well.
Jim Wiggin
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 3:29pm
One was on here some time back had double pulley on alternator.
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 12:59pm
Bob, North Carolina
1949 B
