From 7030 to a 210
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: From 7030 to a 210
    Posted: 15 Sep 2010 at 3:13pm
How complex would it be to make a 7030 to 210 engine swap?  Thanks....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 3:39pm
From what I've gathered from past posts about engine swaps. If it wasn't made for that model tractor or machine then it is going to be a challenge.
I know one would have to fab up motor mounts and have to worry about all of these things that are on one engine that wasn't on another. But that is not to say it cant be done. If you have the time and mechanical know-how then you should be able to do it.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 3:57pm
...and the money. You can do anything if you add enough money into the mix.
Edited by GBACBFan - 15 Sep 2010 at 3:59pm
are genuine." - Mark Twain
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 4:14pm
Would be pretty easy I would think.  Need 210 manifold and turbo to be easiest.  Rear plate will bolt in to 210, front plate needs modified to mount hydraulic pump.  Need to make a cable work for throttle if keeping 7030 pump.  Not sure how the front mount is on the 70xx but probably need short pieces of angle to adapt front engine mount.   My 210 has an N5 engine, it won't be nearly as hard as that one.
Edited by Jordan(OH) - 15 Sep 2010 at 4:25pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2010 at 4:31pm
rear plate for 210 is same as N6, but 7000 series tractors are  different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 10:20am
I thought rear plate was the same from 7000-8000 except the hole for tach?
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 10:49am
Little clarification....Each tractor is complete.  The 210 needs an engine.  The 7030 has a good one and the rest of the tractor is not worth fixing....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 8:35pm
As long as you have both available for their parts it should be no problem.
This page was generated in 0.352 seconds.
