Frame Rail Measurements
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: Frame Rail Measurements
    Posted: 10 Sep 2023 at 12:22pm
My tape read with my old eyes that a
WC - WD45             19 -1/4”
D15 series II             19 -1/4”
200                           20 -1/2”
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 12:27pm
Well, I would like to have the frame measurements from all of the different series. Obviously a D 10 should be less than a D 21. The 160 versus a 220. Etc.
I really want to know the difference of a 170 versus the 200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 4:38pm
170/175 side frame width same as D-15/17/19. Beginning with the 180 thru 7000 had what I call a 3/4" dog leg on each side frame at the bell housing area.
Edited by DrAllis - 10 Sep 2023 at 4:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2023 at 11:55pm
Thank you good Doctor. I would like to talk with you sometime about the differences in 426 engines. 3500, 3750, 670T, 670I and the biggest and meanest, the 670HI. But it is late. Another time.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2024 at 6:21am
Annabella
How do you tell one 'accurate ruler' from another ?
Is it the size of the numbers or the width of the 'markings'?
Gary
Kiniavelly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiniavelly Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 54 minutes ago at 7:25am
I measured mine today and it's 33 inches outside to outside on the front crossmember, and about 31.25 inches where the rails run parallel before they taper at the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 28 minutes ago at 7:51am
What in Sam Hill are you measuring ???   There's no A-C tractor that has frame rail width dimensions like that.
