charging system help |
johns10mm
Bronze Level Joined: 09 Sep 2014 Location: PA Points: 3 |
Posted: 09 Sep 2014 at 7:52pm |
Have an ac b-112 does not charge after tried cleaning contact points in regulator. I accidentally closed cut out contact and blew fuse. Can i test regulator and fix it thanks for any help Jeff
Edited by johns10mm - 09 Sep 2014 at 8:04pm |
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11568 |
Make sure that regulator is grounded correctly. Won't charge if it isn't. If the points aren't that good in the VR, you'd be better off renewing it. Should be good ta' go then...
Steve@B&B |
johns10mm
Thanks steve i finished cleaning contacts,cleaned all connections made sure base was grounded with meter. no its charging around 13.8 volts sometimes up to 14.3 just off idle
