jd fc420v help |
Mrgoodwrench
Orange Level Joined: 03 Apr 2011 Location: CHICORA PA Points: 2081 |
Posted: 30 Aug 2014 at 11:37am |
so a month or so ago my jd 240 started making an engine noise then the counterweight shaft came lose from the block. I assume the noise is from a worn counterweight bushing. I called the local dealer and jd has discontinuedthe counterweight and bushing. does anyone know if Kawasaki still offers this bushing and other internal parts? I called another dealer where I get some other small engine parts and since it had a jd engine number he wont look it up. would the small internat parts be different in the jd engine? I think I can still get the piston and rings from jd to do a complete rebuild. I had planned on replacing the mower but unless I spend about 5k I cant get anything new that is as heavy built as the old one so if I can save it I want to. don't mind spending a grand or so to get it done.
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
farmtoybuilder
Orange Level Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1453 |
http://www.partstree.com/parts/ and other online kawasaki parts places for them. You need rest of numbers and codes to get correct parts.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3302 |
give the model type code or spec # and i will look up some other engine options like a kohler honda or briggs and then see what your local mower shop can do i am just not a kawaski fan is that one water cooled www.tractorandequipmentservice.com
Mrgoodwrench
thanks hudco...it is FC420V-CSOO SER.#FC420-018469. I would consider a repower and maybe an step up in power. the 260 was 18hp on the same chassis so I think it would take it. I like the Kawasaki but parts are hard to find and are expencive. I olny use it in the tight areas and on my sand mound septic and a few banks. I do the rest of my mowing with a b or c but the 240 is a tough little unit and id like to keep it. it ia air cooled
Edited by Mrgoodwrench - 14 Sep 2014 at 8:03pm |
Seth Souerdike
Orange Level Joined: 22 Nov 2011 Location: Cutler Indiana Points: 4113 |
well there's your problem its green!
There are no atheist in foxholes.
Mrgoodwrench
Looks like small eng. Warehouse has a Briggs 17.5hp kit for $675... I think it will cost that to fix the kawasaki if I can find all the parts.
