Model B final drive: What am I doing wrong?
Steve Jelf, So KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Jelf, So KS Quote  Post ReplyReply Direct Link To This Post Topic: Model B final drive: What am I doing wrong?
    Posted: 09 Aug 2014 at 11:28am
OK, I got the new bearings and other replacement parts put in, so I set about reinstalling the thing. I thought if I rotated the shaft until the splines lined up, it should slip right in. But the shaft seems to be hitting something solid. The second picture shows it at that point. I won't go in any farther. What's the secret?
Edited by Steve Jelf, So KS - 09 Aug 2014 at 11:30am
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 11:32am
Sometimes you have to wiggle it up and down or side to side and then it will go. BTDTClap
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 12:16pm
Did you have both final drives off at the same time and did you change the seals and or the bearings in the rear end housing?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 1:01pm
Your just humming the wrong song. Try a different one and wiggle all around at the same time and it will slip right in. That gasket in there is not needed.
If you have no dings or burrs when the splines are lined up it will slip in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Jelf, So KS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 1:05pm
No, only the left side was off. I didn't change anything in the housing. I thought if I put the tractor in gear to keep the transmission from turning and then turned the shaft, that would line up the splines and it would slip in. No such luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Jelf, So KS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 1:08pm
I'll add some grease and try again.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 1:10pm
Bottom looks deeper in than the upper part. Got to go in even.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Jelf, So KS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 4:26pm
No amount of raising and lowering for the right angle, jiggling around, extra grease, incantations, or musical accompaniment will get it to budge past where it is in the picture. I feels like it's up against something solid, but I can't see it. This is really infuriating. I'm quitting to cool off. I'll try it again tomorrow.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 4:43pm
It should slide right in with some movement. The only place it would be hitting would be infront of that shaft in the axle hole. Pull it out and look in there to see if something may have miss aligned somehow. I've don't tons of them and never had an issue. I've had to get physical with a couple before that question the risk of my back but everyone went in.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 5:15pm
I would block the bull gear pan about level, place your chain up closer to the transmission to where it is almost at a balance but heavy on the axle end. That way you can grab the axle and move the final drive in all directions without breaking your back. Once the axle starts to enter the splines you can adjust the chain up or down to go in the rest of the way. You will not want to put a lot of pressure pushing inward until the shaft starts to enters the splines. As you turn the axle you will then be able to feel the shaft catch and start to enter. You can measure the flange top and bottom to make sure the chain is at the proper height before you start.
I thought I had taken pictures of one being installed but I failed to find one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 8:59pm
In addition to moving is from side to side you have to rotate the axle until the splines line up. Good luck.Smile
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 9:08pm
Is the brake in that area ? It is in the D 10s and I had that problem until I released pressure on the brake band. Then it went in. Did you put in new bands ? Maybe too big for the drum ?
I used to be young and stupid, now I am not young anymore.
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 6:28am
Can you turn the final drive axle with a strap wrench or something?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 6:37am
patience is the key. You're smart to walk away, try another day !!! I'm betting a little 'rejigging', a fresh coffee and it'll slide in 'slicky smooooooth'.
You do NOT want to 'force' it.Bad things happen then.
Have a second set of hands,maybe to turn the axle shaft or another set of eyeballs o be sure it's lined up and square all ways.
patience, ya gotta have patience....
if you want to practice, my D-14 needs to be split for brakes..... LOL
jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 9:36am
Normally if it wont go into the spline, the splines were enlarged by smacking the shaft when removing the brake drum and bearing. Pull it back out, take a mike and check the OD of the spline in the first inch and then back 2 inches. You may need a file to take off a few thousands on the OD and cleanup the spline root.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 11:12am
Steve,  I never had to do what you are doing.  However, listen to what is said above.  You are getting some outstanding information from some outstanding mechanics.
Don't get too frustrated at my favorite.
Thanks for taking such good care of it.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Jelf, So KS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 11:51am
Like Red Skelton's Mean Widdle Kid, "I dood it!"
I gave the end of the shaft a thorough cleaning and a close inspection.  It looked to me like the ends of some of the splines were mashed wide.
After a bit of filing, I slathered on a little grease, raised the hoist, and shoved the shaft into the housing. I pried the bull gear with a screwdriver to turn the shaft until the splines meshed, and with a little jiggling the thing slid in the rest of the way and I had it bolted back on in less than five minutes.
It may take me the rest of the day to put everything else back on and reinstall the mower, but with any luck I should be mowing tomorrow. I am a happy camper. Thanks to all for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 1:12pm
Don't ask me how I knew that !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 4:05pm
GREAT!!!
Delighted to see my favorite back in action.
Good Luck!
Bill Long
This page was generated in 0.301 seconds.
