turbo |
200 allis
Silver Level Joined: 11 Mar 2014 Location: new jersey Points: 201 |
Posted: 11 Mar 2014 at 7:19pm |
i have read on here guys using hx 35 turbos but there are a bunch of different ones thought maybe someone would know sizes to use
O.P.S. Heads
Orange Level Access Joined: 02 Jan 2013 Location: Iowa Points: 574 |
Open RPM or limited?
O.P.S. Heads
And how much fuel delivery? What pump are you using?
200 allis
I'm running 3000 rpm and standyne pump with 390 head with 7080 injectors opened up more
O.P.S. Heads
Most any HX35 you find will have the same turbine wheel (70mm in and 60mm out) so that's easy. You are right. There are a few different compressor wheels and covers. I would start with any of them that have a 65mm inlet (2.20 inches). The seven blade version would be optimum, but the eight blade will work fine too. Find the tightest turbine housing you can. I would even use the 12cm waste gate housing with the gate tied shut. The issue there is that you have to make an adapter plate between the exhaust manifold and the Holset turbo to convert from the T4 pattern on the manifold to the T3 pattern on the turbo. They offer these plates on Ebay if needed.
I have heard that an Air Research Turbine housing can be used on the Holset turbo by machining the I.D. of the Air Research housing. That would be a slick installation if it could be done. Use the same exhaust elbow to go through the hood. I haven't tried it, just heard about it. How big did you make the injector orifices and how much fuel does your pump deliver? |
200 allis
thank u for the info. I figured on making a adapter plate. When u say 12cm housing where is that measured. Do recommend using a used turbo. I am not sure of orifices size or fuel. A guy in pa set it up the for me.
O.P.S. Heads
The size of the turbine housing is stamped or cast into the housing. Typically on the outside near the foot where it bolts to the manifold or can be stamped just inside of the inlet. I think the 12cm wasted housing was very common on Dodge trucks with the 5.9 Cummins.
A used turbo will work fine as long as it is in good condition. My question on the injector orifice size is important. If they are too big it won't run very good no matter what the turbo is. I would say a maximum of 4 holes with .020" orifices. It may have worked just fine with the 7080 injectors depending on the amount of fuel the pump is delivering. Be sure the injection pump timing is no more than 34 degrees if your conn rods are not heat treated. Edited by O.P.S. Heads - 12 Mar 2014 at 3:12pm |
2wise4agm
Orange Level Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
What size are the 7080 tips?
Orange Level Access Joined: 12 Sep 2009 Points: 19586 |
7080 tips factory stock are .0148" I think.
O.P.S. Heads
Yep, I remember them as being just under .015" X 4 holes. I would guess the 7580, N5, N6, nozzle tips are the same as long as it is the Allis injector - not Bosch?
One other thing, the newer, low profile, o-ring type Allis injector bodies have a larger fuel passage through them from the line to the tip. That helps performance too. The older ones can be drilled, but it's not much fun. Edited by O.P.S. Heads - 12 Mar 2014 at 5:28pm |
7080-7580-old N6 with AC injectors should all be the same .0148" 4 hole tips. I don't think I ever saw an N5 with AC injectors, but if so, they were smaller holes and the Roosa pump had .290" plungers versus the N6 at .310" plungers and 2850 top rpm's.
200 allis
I think the orifice are .020 and definitely 4 hole
O.P.S. Heads
If that's what they are you should be OK.
200 allis
It was funny u had mentioned the timing because mine is set at 35 degrees. I had ran tractor one time with this fuel set up and stock turbo and lost a cylinder after pull. Took head off thought exhaust valve were really tight. Thought they had carbon hanging them open cause egt. Got hot then I found bend rod
200 allis
It ran real strong pull but that was it.
O.P.S. Heads
I prefer 32 degrees myself especially at 3,000 RPM.
Is the head still off? Do some smoothing up of the ports if it is and add a nice valve job. You will be happy you did. |
200 allis
Head is still off I had it gone over 30 pound heavier springs heavier keepers,valve job and he cleaned the ports out some
200 allis
When they set the pump up they told me to put it at 35 degrees u thinking It would be better 32. I'm debating whether to have the rods harden
O.P.S. Heads
If you have the rods hardened properly you will have no issues. Yes 32 degrees is safer. With hard rods you could run 35 - 36 degrees. Much more than that and it may not lug as well as it would from 32 - 34.
My buddy has a set of six for $165.00 each. You would need to use new bolts when you install them. Think about it: If you have already folded a rod and you plan on making more power, you will probably fold more rods if you don't change something. Edited by O.P.S. Heads - 12 Mar 2014 at 6:34pm |
200 allis
The rods are already harden
200 allis
I meant the rods your buddy has are harden
O.P.S. Heads
Yes they are hard. You will not bend them.
200 allis
I am interested in them and where could I get new bolts.
O.P.S. Heads
Any Agco dealer.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4783 |
In order for my Roosa fueled 426 to run right, I've got to be in the 40* range. Hardened rods are a must.
