Structures 1964 Allis D15 Series II
 Post Reply Post Reply Page  <12345 12>
 Rating: Topic Rating: 3 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2014 at 8:05pm
very nice
Life is tough,but it's tougher when you're stupid. - John Wayne
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2014 at 10:03am
Guys appreciate the comments!  Thank you.
Was able to get the patches in.
Fourced View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fourced Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2014 at 11:24am
Double check the bottom tank on that radiator, I bought an aftermarket and the bottom tank was about 1" thicker front to back than the Stock one. The mounting holes won't line up because the tank hits.
Edited by Fourced - 07 Dec 2014 at 11:27am
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2014 at 12:36pm
Looks very good.  I would suggest grit blasting the rough areas and applying some good quality epoxy to smooth out any low spots.
After the epoxy has set, sand blast the entire wheel.  Prime and paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2014 at 11:08pm
Yeah you're right.  The tank is hitting the power steering casting.  I might be able to work the tank in to clear the casting though.
JGAnderson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JGAnderson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2014 at 3:53am
Nice project... I woke up my dads series ii D15 just this fall.  Had sat in a pole barn for the last 5 or 6 years at least.  Going to use it to push snow this winter, then start tearing it down this next spring.  I am taking plenty of notes on what you're doing!LOL
63 D-15 series ii
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2014 at 4:58am
Simple solution might be to grind some off the casting where it hits the tank.  I re-used the tanks on my original, just had it re-cored, to avoid this problem. Still cost about $450...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fourced Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2014 at 11:31am
I got mine from Reliable Aftermarket Parts INC on E-bay. I am now fighting with them because they will not refund $60 in shipping charges, the auction says it will fit, it won't. I don't think that is my fault.(rant over)
I returned it because the hood would not fit correctly with everything stretched out to fit the bottom tank.
Edited by Fourced - 08 Dec 2014 at 11:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2014 at 9:55pm
Trying to do a little bit each night.  weld, grind, grind, grind... weld, grind, grind, grind... Big smile
I had pretty good penetration with the backside welds but I went ahead and welded the inner side of the rim patches.  Trying to not use any filler.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2014 at 4:45am
Nice! Its not that hard to fix the wheels. The hardest part is just getting started. You are saving my favorite tractor. Wish Ida kept mine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2015 at 10:41pm
Had some time off for the holidays and spent a little time sand blasting and I also dipped a rim in an electrolysis bath.  It helps cut down on the sandblasting time.  Hopefully I'll put some paint down soon.  The first pic shows where I hammered a flat into the repaired rear rim for the schrader valve.
Edited by structures - 01 Jan 2015 at 10:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2015 at 8:05am
Robert,
Found this thread again! Sorry I have been busy.
I think your coming up on a one year anniversary? Your doing a good job on your Dads tractor restoration! All your fabrication work looks good. (I like to fab things) I can say that these tractors are a lot of work. Use this forum to keep yourself motivated. Take lots of pictures and post them. Its a good break for you and helps show your progress!
 We are here for support! The folks on the Allis Forum really did help me a lot as I worked on the WD projects this past year too.
Looks like your finding a lot of the same issues I had. The work on the rims looks very good. I also use a electrolysis tank/s. But did not have one big enough for the rear rims. So I had those blasted, then started the repairs. 6 rims to make 4:) Great that you have a sandblaster too!
On that radiator fit issue. I think I would look at modifying the casting too. But before that, is there anything else that is going to be a issue? Old man Casbohm says "you change one thing and five other things may need changed"!
One thing repaired/restored at a time and you will get there!
That rear rim with the POR black looks awesome. I will remember that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2015 at 6:05pm
Hey Chris. Yeah 1year into it... Hope 2015 yields more progress! I'm gonna set the radiator issue aside until I get the tractor rolling on 4 wheels. That's true about changing one thing and creating more issues. I got a '65 Chevy truck I'm restoring wish I hadn't done so much customizing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2015 at 6:09pm
Robert,
I have enough trouble trying to get near stock. I applaud you for doing custom work.
Post a picture of the truck too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2015 at 6:25pm
Robert,
The truck is a long story. Lots of pics over here: Structures 65 Chevy
Couldn't have said it better myself!
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2015 at 11:16pm
Robert - What a great job of picture taking and posting on your restoration.  I just came upon this thread today, so was treated to a whole year of progress at one time.
You do great work!
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2015 at 7:43pm
You do great work!
Thanks macvette
Was able to lay some paint down last night and today.  Been so cold I've left the heater in the garage on all night, and I'll have to continue through tonight  $$$
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2015 at 6:34pm
Robert,
The fresh paint looks great on the wheels and hubs!
Hey I read your entire thread on your Chevy Truck restoration! Awesome! Dad had one very similar to yours.
 This tractor should be a piece of cake for you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2015 at 6:57pm
Thanks Chris.
Folks got a little more done this weekend.  Instead of brushing the por15 I sprayed it.  Looked okay.  Put some paint on one front wheel.  I have another wheel on order.  Last I dipped my eccentrics into an e-bath for tonight.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2015 at 7:18pm
Good progress. Seems like once some new paint gets laid on, the pace picks up. Stuff starts to look new then, and generates some enthusiasm. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2015 at 1:13pm
Blasted the eccentric fittings and pins.  Some of the pins are pretty bad, but I think I'll go ahead and use them.  If they break I'll replace them.
Very true.  Thanks!
Edited by structures - 14 Jan 2015 at 1:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2015 at 5:50pm
Fill the pits with some epoxy, worst thing that could happen, is to have to remove them and replace them...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2015 at 7:03pm
Robert,
I need to bring my e-tank inside. Its a solid block of ice. I could be using it. I ended up wire brushing my wheel brackets and pins.
What I did on those eccentric pins that are pitted is to grind the rough areas smooth so that when rotated they don't bind. We are working on some of the same stuff:) I just got my WD rims together.
Did you get new "C" snap rings?
Your cream looks very good. I just tossed a front rim in the truck yesterday that needs the tire removed, blasted and the valve stem hole repaired.
Looks like your ready for new rubber.
Keep the pictures coming.
Agreed that some fresh paint helps keep the interest level up, and can keep you going. Assuming the pocket book can keep up:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2015 at 8:12am
Yeah kinda what I was thinking.  Thanks.
Robert,
I'm not having much luck with the e-tank at 30 deg F.  The soda is not mixing well and I think the cold is slowing the process down.  It definitely works, just not as well as I'm used to.  I'm trying to keep up with your progress, you got 2 builds going on!  I don't have new snap rings, but I seen your post about picking them up from the parts store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2015 at 8:24am
Robert,
 Check your connections, scrape the plates in the tank, and recharge the tank with some more washing soda. I have had good luck even in cold weather before.
I never had very good luck doing much more than 1 piece at a time, Not sure why, maybe just surface area.
Sandy Lake had new clips.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2015 at 7:48pm
dave has it all straight and level.tractor overall looks not too bad.on my 700 dollar wd-45 diesel,things looked like a good parts tractor.but as it turned out.it was a diamond in the rough,has won me several.first place pulling titles,and all systems worked.it set in the woods near dubac la.for 9 years.its amazing what a little tlc can yield you.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 1:25pm
I painted some more on the wheels.  Should be ready for rubber now.  I did buy a new front wheel and I'm going to paint the center because the white it came with is darker than the white I have.
I also have been playing with plating.  I'm putting a zinc plate on the eccentrics to help with the areas I wasn't going to paint.  Turned out okay.  Should provide some good protection, I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 2:24pm
Interesting. Keep up the good work on what is my favorite tractor!
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 7:48pm
Great work! Love watching your progress.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 8:09pm
The rims looks real good! Nice work.
What is the plating process? Zinc?
