D17 with 301 |
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6351 |
Posted: 19 Sep 2013 at 9:35am |
Charlie
mattb
Orange Level Joined: 11 Jan 2011 Points: 348 |
I cut a hole in the front bolster so crankpulley had room then put a hyd cylinder on front axle to push pull drag link for powersteering the back of the engine is all from a 180 which bolted right up. Had to grind a little out of the bellhousing
Charlie175
That is just cool. So I assume you are getting 70 or so HP out of it?
How does it pull? I always thought of putting a 200 ci from a 6000 series in a 17 or 19.
Charlie
Glockhead SWMI
Orange Level Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
Tight fit. Looks good.
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33663 |
Like that injection pump...more pics please... sure think thats neat.
Jamez99
Bronze Level Joined: 20 Sep 2013 Location: UAS Points: 1 |
Thanks
you for updating us with this interesting
information. you did very great job. keep it up
http://www.units.it/ http://www.free-braindumps.net/201-01-pdf.html http://www.eccouncil.org/ http://www.ucla.edu/ http://en.wikipedia.org/wiki/EC-Council https://www.facebook.com/ECCouncil http://www.youtube.com/user/Apple Edited by Jamez99 - 25 Aug 2014 at 7:12am |
http://www.eccouncil.org/ |
mattb
ive been pulling this tractor for about 5 years if u look close you can see the blocks purple that's a big al engine in there its susposed to have came out of an army truck
XT in pa
Orange Level Joined: 21 Apr 2011 Location: hickory pa Points: 711 |
That's real nice. Any videos of it pulling ? Shawn
190XT,D17and 7045
JC-WI
One of them purple people eater engines?
WildBill
Silver Level Joined: 26 Aug 2012 Location: Mandan,ND Points: 190 |
I SURE WOULD LIKE TO SEE MORE PICTURES OF THIS ANIMAL ! I THINK ITS COOL ! THERE IS LOTS OF RESERVE HORSEPOWER FOR A 301 ! I SEE IT HAS A SIMMS PUMP ON IT . THAT WAS A REAL EARLY 301 ... DOES IT HAVE THE PLATES AT EACH END OF THE CYLINDER HEAD ? YOU COULD PUT A TRICK 11MM A -PUMP ON IT AND SOME NICE INJECTORS THIS WOULD BE A NICE SLEEPER. I SUPPOSE THE CLASS WILL NOT ALLOW TURBO'S ? LOT OF POTENTIAL UNTIL THE DRIVELINE OR CLUTCH GIVES OUT.
IF YA CAN SOMEONE WAS ASKING FOR A VIDEO THAT BE REALLY NICE TO SEE
Allis fan for life ! B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3248 |
Probably a hybrid gen set eng. the LH fuel pump block off has hole pipe plug and block off for RH oil cooler is different color. Most of those were freeze plugs on early 2800's. A natural asp 2800 with a Simms - I have never seen - but then they made a bunch of special apps for special orders. IF it has the bubble in the front of the oil pan then is was not an early eng. Fun trivial stuff
DarrylinWA
Orange Level Joined: 12 Sep 2009 Location: Amarillo Texas Points: 1898 |
Brad TeVelde has one in in D 17 puller narrow front. Pulls 5000 lbs and about 10 plus mph.
Work of art this thing is!!! Neat stuff Darryl |
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
mattb
Engine was originally turbocharged. Had oil cooler also.
mattb
Plate on the left front side of the block youcan see in the picture says it was specked for a mack truck.
tbran
Thanks(1)
What MACK truck had a 120 Hp engine?
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7947 |
Thats what i was wondering!! Id hate to drive that thing ! I couldnt imagine any truck other than a pickup having a 301 in it
Edited by DougG - 22 Sep 2013 at 12:28am |
blue924.9
Orange Level Joined: 22 Mar 2013 Location: George Iowa Points: 1082 |
lotta old trucks had big al motors in em,
Glockhead SWMI
There was a bunch of info on the Big Al engines in the construction section recently.
tbran
Big Al was 844 cubic inches - a 25000 series.
DougG
There were 5 different versions of them,from 301-844 ci but the true Big Al was a 25000 series 844 ci
