govenor help |
Post Reply | Page 12> |
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6351 |
Posted: 21 Jul 2013 at 8:37pm |
My D17 performs better with the 175 spring
Charlie
firephight
Orange Level Joined: 16 Sep 2012 Location: st.louis Points: 320 |
Ok got my 175 blue strip spring installed compared to the d17 spring I have its a lot more stiff tiny tach is at about 1090 now guessing the tach is not picking up the #1 wire correct. Now next quesr ion if I advance (turn the dist) till the engine starts to run rough then back it off till it smooth es out will this help when the tractor gets under a load?
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3746 |
moving tach wire to coil will give you 4X rpm cause it will read spark for every plug instead of 1 cylinder
firephight
Waiting on the spring I ordered. Also found a dwell/tach meter so gona check my dwell and then timming then adjust cross shaft if needed and move my tinytach pickup wire to the coil wire.also might look into HEI for hotter spark i have already converted to 12. I would just think my tractor should spin out in the #3750-4500 but it just runs out of power
Orange Level Access Joined: 12 Sep 2009 Points: 19598 |
WAITING FOR A REPORT BACK. |
If the governor vertical arm needs to be bent (one way or the other) to make the hole line up with the link rod, you bend the vertical arm, NOT TWIST THE SHAFT. A-C made a tool for doing this adjustment.
The first thing you need to do is cut off or severely bend the cotter pin legs on the link rod at the carb throttle shaft. That cotter pin cannot in any way interfere with the operation of the linkage. Cut off the cotter pin legs short and spread them opposite each other or bend them around the rod end so they cannot touch anything !!!!! The link rod cannot be rubbing against the engine block either. With the engine off and hand throttle wide open, disconnect the link rod from the vertical governor arm behind the generator. Now, force that link rod rearwards as far as it will go. At this point the carb is wide-open and the throttle shaft is up aginst the lever stop. While still holding the rod rearwards against the carb stop, try and connect it to the vertical governor arm WITHOUT MOVING IT FORWARD. The link rod should just slide into the arm hole without moving the arm OR the link rod forward. Bending the vertical arm might be needed to "synch" this linkage. It shouldn't be that far off, but whatever it is, it is. I'm also questioning your tachometer as to it's accuracy. You certainly should have checked you eng max RPM's before you started changing things.
firephight
Dr.allis do you think I need to bend my cross shaft I bought this tractir and never checked the rpm before so I don't know what the stock setting was
mattb
Orange Level Joined: 11 Jan 2011 Points: 348 |
do u have a adjustment bolt on top of the aluminum cover for the governor? If u do remove it and jb weld the hole shut that is for a combine governor only and wont let u put enuf tension on the spring to get the rpms u want.
Set hand throttle to wide open. Disconnect the carb link rod behind the generator. Grab the vertical governor arm and move the top of it towards the radiator. It should only move until the arm is probably straight up/down and the fork on the other side of the engine is bottomed out against the timing cover. Now, let go of the governor arm and it should spring backwards towards the carburator, and stop at some point. The governor arm is "pinned" to the fork on the other side of the engine. Whenever the arm is moved the fork should move. THERE CANNOT BE ANY LOOSENESS in this pin area and it is rare to have a problem like that. If you can move the gov arm at all easily without stretching the gov spring, the tapered pin may be loose. Also the link rod to the carb should move back and forth very easily with no binding whatsoever when disconnected from the gov arm. I can visually see nothing wrong here. Do you have the gov arm synched to the link rod correctly?? It really shouldn't be a problem as things were just fine until you changed springs. I could fix it in five minutes if I was there.
wrightk20
Bronze Level Joined: 04 Jul 2010 Location: wisconsin Points: 52 |
Then what's the point in you saying anything? Just more jibber jabber. Dont clutter this post with bs please.
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
if you pull the pins and remove the weights in you picture . get a piece of aluminum to slide on shaft to hold rocker arm spring up off shaft . cut spring to length and put pilot bearing back on shaft to work fork you will never break weights again but at the rpms your running that will never be a issue
Edited by mlpankey - 04 Jul 2013 at 11:39am |
firephight
the last pic is at idle just wanted to show how the linkage was
firephight
the carb side is with the throttle wide open
I want to see pictures of the carb side of the engine, with the hand throttle wide open. One pic of the governor arm behind the generator and another of the carb linkage up against the engine blcok. I see nothing wrong with any of these pics......nothing.
firephight
some pics so some could help me out
mattb
If u got an e combine carb iv seen the arm slip on the butterfly shaft too.
mattb
make sure the bearing is not froze up on the shaft in gov.
firephight
Put the stock wd45 spring back in and only can get 730 rpms at full throttle its like the weights are realy pushing the fork back to idle. Has anyone lightened up a set of weights if so how much?
firephight
How is that if the 175 spring is aready rated at 2, 000 rpm? Factory specs. Next question does the 45, d17,&175 have diffrent weight govenor weights?
I gave you the p/n to a new D17 spring (70229519) and now you spend money on a new 175 spring? ..That will get you 1800 RPM and the D17 spring will get you 2,000 RPM if everything is adjusted/assembled correctly. |
firephight
Part #70226785
firephight
Dr allis I am going to try that and may take the govener assembly out and make sure the spinle that the thrust bearing rides on is not bured up or have a grove in it that when its spinning its keeping it from moving outward.I also just ordered a new 175 spring
Put your old spring back in and see if you can get the RPM back that you had before things went south.
firephight
Guess I should also mention tha my tractor has factory power steering so the throttle linkage is a little different
firephight
Kip its a d17 spring saw the tractor myself
mlpankey
when the engine is running how does it sound? When i first got involved in pulling years ago and started trying to up the rpms . I had a engine that didn't respond to spring changes raising the rpms as it should. I would try and a pop in the exhaust would get louder and louder . Long story condensed on fix the valve springs were shot valves would start floating at 1500 rpms . Went to the comp 920 and 944 springs never had that problem again. May not be your problem but they can be other issues not letting rpms raise from gov.mods as it should is my point. pulling carb wide open bypassing gov will let you know if its something other than a improper adjusted gov.
Edited by mlpankey - 01 Jul 2013 at 8:01pm |
Kip-Utah
Orange Level Joined: 14 Sep 2009 Location: Southern Utah Points: 855 |
I don't think that you have a D17 spring...but even a WC spring should give you 1300-1400 rpm??
HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
firephight
Maybe the spring is weak it was a used one.I did the throttle wide. Open and made sure the carb was wide open with engine off. Started the tractor and whent to wide open and the carb only opens about half I can manualy push the vertical arm twords the carb to increase the engine speed
I can't imagine what is wrong here. All you had to do is remove the governor front cover and replace the spring/plunger. There was no need to change anything on the carb side of the engine unless you took the governor apart. Where did you get your new spring?? and what was the P/N?...should be 70229519 from AGCO.......this should have been as easy as changing out 4 spark plugs. If the engine ran 1700 rpm before, it should run 2,000 rpm now.
