where to get a 175 cam |
Post Reply | Page <1234> |
Author | ||
wi50
In very simple terms, duration is measured in crankshaft degrees of rotation. Meaning that if a cam has 200*@.050" lift of duration on the intake lobe, the crankshaft rotates 200* from .050" lifting of the lifter
to .050" from being closed. Then there's valve lash adjustment to take into account and rocker arm ratio. So the first bit of lift is used up taking the slack out of the parts, then more is used to get the valve off it's seat to the point of it allowing air to start moving or in the case of the valve closing to allow air to stop flowing into the cylinder. So if you have 180* of crankshaft rotation from TDC to BDC and your can has say 200* of duration @/.050 lift, then the valve has to be moving before the piston reaches TDC and it's still not closed after BDC right? This is where we take into account cam timing. For some math let's say that cam with 200* if intake lobe duration is timed with the intake centerline at 100 degrees ATDC that means that 5he can lobe is exactly half way through its movement when the piston is at 100* past TDC. So the post on still has to move down for another 80* of crank rotation, the valve is open for 100* or 20* past BDC. The incoming air charge into the cylinder has inertia, it can overcome the post on heading in the bore some and still charge the cylinder for some time but eventuallyt the piston movements will cause a reversion. There's typically 2 numbers for duration, one is advertised or seat duration measured as the lifter starts moving to the point of closing a few thousands and the other is measured at .050". The difference tells us how fast the can ramp is, or how aggressive it is. That's all for now, but hopefully give a basic understanding. Edited by wi50 - 26 Aug 2014 at 5:36pm |
Sponsored Links | ||
mgburchard
Orange Level Joined: 14 Sep 2009 Location: Tennessee Points: 1123 |
The wizard says ramp rate or lifter acceleration depends solely on lifter diameter not duration. In fact the math for maximum velocity goes like this example he gave me lifter diameter 1.250 x 3.14 or pie divided by 360 gives you inches in degrees so .0109 inches in degrees is a fast as a 1.250 diameter mushroom lifter can be accelerated . The wizard went over this with you when you was arquing that 60 teeth in 360 degree was a 6 degree timing change but now your agreeing with wizard that its more . the allis 226 can gear tooth is about .400 thick a 8 degree eccentric cam bushing has .090 more material on one side . if .090 is 8 degrees how much is .400 ?
mgburchard
Wizard says intake closing point can be figured by advertised duration as follows 280 ÷2 =140 +LSA 112=252 - advance ground into cam along with 180=68 degrees abdc
wi50
The morning crew will love this abomination of geometry....you boys have a lot to learn. If a gear has 60 teeth, there's 6 degrees per tooth, if its a can gear driven at half crankshaft speed, then 12/degrees per tooth. Basic math boys and girls. If you place an offset bushing in it, the offset would depend on the bushings placement from the center, or in other words its radius....again basic geometry. When we get to a more complex geometrical shape such as a cam lobe, lifter acceleration is controlled by a combination of cam profile and lifter diameter. Part of this can profile is the difference in duration from one lift compared to another lift. Advertised duration and @.050" duration are a result of the ramp profile of the cam, thus controlling the lifter. You should have listened to me earlier and taken the whole day to use Google, it appears a few hours weren't enough for you to learn enough. Edited by wi50 - 26 Aug 2014 at 7:15pm |
wi50
You are doing a fine job reenforcing my point that a can with 280* of duration no matter how its measured is to much for the engine in question.....though for a highly boosted engine at high speeds it works fine. |
mgburchard
Big cams for big engines little cams for little engines . so if I was building little engine 207 duration at 50 and .365 lift on cam give a net valve lift with 1.5 rocker of .5475 suits you call Charles at can craft lol
mgburchard
As wizard said and has always said i
A cam tooth is more than six degrees your good at looking up his old post to see where you argued that it was six degree instead of more that you are now in agreement with the wizard that it is . |
mgburchard
Wiz says 56 degrees of overlap just qualifies as a mild performance cam and that's what the 280 advertised has.
Butch(OH)
Orange Level Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3829 |
One of them did Marty can you imagine trying to get past the most simple of problems??? Gesh, kind makes a guy feel sorry for em eh? |
mgburchard
Wiz said you probably wouldn't get this cause LW didn't but if you built a 4.125 bore 4.5 stroke flat top piston .250 below deck should be 16.2 static compression but if you used a 280 advertised can with intake valve closing 68 abdc and a 7.5 stock length rod your dynamic compression is 12.5.1and motor will run fine on 110 motor octane race gas .
Orange Level Access Joined: 12 Sep 2009 Points: 19557 |
And to "run fine" on 110 octane fuel, what exactly is your ignition timing set at for 2,000 RPM running???????
Larry(OH)
Orange Level Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1576 |
what are you talking about not working for me Pank?
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
mgburchard
The isky cam you traded to Pankey didn't work for you . The cam Pankey gave you in the trade from what I gather did work for you. Is this correct Larry ? Did Pankey spec a working cam for you? . here's a anoalogy Pankey left me with last night . you have a swimming pool and are filing it with a garden hose . the time the valve is open to closed when the pool is full is duration now fill the pool with a fire house time hydren is open till valve is closed is duration . so when by Marty's account the intake port of allis is the garden hose . the question is why would you want less time for garden hose to be open
mgburchard
Pankey wants to know Larry Ohio when you ran the isky cam profile in a small cubic inch allis did you ever burn a exhaust valve like Marty seams to think that cam profile will do .
wi50
The wizard is full of wis-dumb.
280 degrees of exhaust duration won't burn exhaust valves, but slow ramps will. You see the numbers on a cam card are important there pank. Seat duration and @.050" tell how the beginning of the ramp is shaped.....but I've covered this before and you haven't quite picked up on it yet. But what 280* of exhaust duration will get you is a real short power stroke and a lot of overlap. In fact on a siamesed port 4 cyl engine like the allis, you'd have 2 intake valves open at the same time on the same port, one opening and the other closing and one exhaust paired to the opening intake open also as well as one exhaust opening on another cylinder on the engine. The result would be a sonic crack transfered to the intake.....long story short, draw it out on paper for yourself pank. You really don't know what you're talking about. The engine wouldn't make enough power to drive across the yard. Those numbers on a cam card mean something. Learn what they mean, how to interpret them and how they relate to the engine....again come back tomorrow and try to display some level on intelligence. |
mgburchard
What you didn't get from the wizard is the diameter of lifter sets the ramp speed . he gave me the formula and I posted it in prior above posts. So if it is slow like you say then Larry should have experienced a burned exhaust valve .
mgburchard
Marty you see Larry ran that isky cam so it had real world testing and not computer WiFi testing . so if it burned a exhaust valve in a low ci engine he will know ?
cranky
Orange Level Joined: 08 Jan 2012 Location: easton md Points: 205 |
can you please explain to me how lifter diameter sets the ramp speed? thanks
wi50
I'm certain you are not bright enough to know what you're trying to argue about. I'll outline it so your simple mind can understand it.
You are saying that you think a camshaft with 280* of duration on both lobes makes a good pulling camshaft in this siamesed port 4/ cyl engine. Though you don't know the other specs on the cam, and those with new found fascination of the internal combustion engine would only look at the big numbers. I'm saying that there's no way a camshaft with 280* will work (in this application of course) unless of course the @.050" numbers are very low, in which case the ramps would be to slow to be any good, and that you have a poorly designed camshaft if it does work..... At least you can go back to the drawing board now and make up some bs. Maybe you'll figure out why you were unable to move the pulling sled when you put the cam in your engine...... |
wi50
He can't. Though you know better, it is fun to amuse oneself at the expense of idiots isn't it. At least for a few minutes anyway. I'd imagine panks cranks with his Gleason has taken all the work on the east coast and his 5 highly skilled employees are carving out billet cranks and you are bored today. We'll have to catch up sometime. |
mgburchard
Remember the formula Pankey gave for maximum lifter acceleration . a allis 1.250 mushroom lifter will always have a faster ramp to .050 than a automotive .904 roller lifter .call Charles at cam craft
Butch(OH)
I am sure that the Whizbanger will have an entertaining, but largely fact free response but until he comes back to entertain us the actualities are this. In order to gain EFFECTIVE duration and lift over and above stock a cam grinder wust increase the ramp quickness or speed meaning that in a given number of degrees the lifter rises X amount. But there are limitations, accelerations come into play at some point but on this subject the limitation is this. With a flat tappet the faster the ramp the more the actual contact area moves away from the centerline of the lifter. If the contact area moves off the face of the lifter it isnt hard to imagine how long things will last, about as long as the Whizbangs pulling engine did. Knowing all this it stands to reason that if lifter diameter gets in the way of a certain requirement for ramp than increasing it will allow the ramp to be increased by the person designing the grind. |
Butch(OH)
Marty, I think it goes way past all that? I was gazing out the window and it hit me!! I have one of these hanging outside my big window. Hey Whizbanger, these are not degree wheels!!! Its a thermometer, different kind of degrees!!!! No dang wonder the boy is so confused!!!! Edited by Butch(OH) - 27 Aug 2014 at 10:10am |
O.P.S. Heads
Orange Level Access Joined: 02 Jan 2013 Location: Iowa Points: 574 |
OK that thermometer thing was funny.
To Marty If I understand correctly with all things being the same other than the cam grind, a cam with a advertised duration of 270 and 220 degrees of duration at .050" will have a faster ramp than a cam ground with 270 degrees of advertised duration and 240 degrees @ .050? That stands to reason as the lifter will have to travel farther in fractions of an inch in the same amount of time(in degrees) with the 270 / 220 cam. Correct me if I am wrong. I am a simple man. Edited by O.P.S. Heads - 27 Aug 2014 at 11:02am |
mgburchard
If advertised duration is measured at .004 lifter rise then the duration will be greater than it would be if measured at .015 lifter rise .
Larry(OH)
Pank, I never burnt any valves, but always was twisting that engine for all it was worth. It ran and pulled good, but I knew it was not any good for low RPM, so out it came. I have a Barney cam in it and the other I traded is still setting on the shelf waiting to go. I will see if I still have the numbers for it to post them here. I gave you that info so post it up. It had lots of lift and duration. That engine was not lazy at all. The cam had been passed around the neighborhod like an old whore downtown. I cannot take credit for ordering the profile, just using it. Yes, I ran a small cubic inch but never had any problems keeping up, just the Ollies had bigger engines around here
wi50
Think of it this way Mike, with all things being equil other than the .050" duration the lesser duration cam has to rotate further from advertised duration to get to the .050" of lifter rise, the lifter accleration is slower.
If I have a 270 / 220 duration lobe the cam rotates 25 degrees of engine rotation or 12.5 degrees of camshaft rotation to achieve .050" lifter movement. If I have a 270 / 240 duration lobe the cam rotates 15 degrees of engine rotation or 7.5 degrees of camshaft rotation for the lifter to move .050" I bet you've found out what to much duration does....the engine hits a wall and the torque goes flat, trim the duration back and they'll run like crazy. So in this case if we use that 280 degree cam that pank thinks is so great, we simply can't have per say a 240 degree @ .050" duration, we would have rapid lifter accleration, but again for the siamesed port 4 cyl engine will not tollerate 240 degrees of .050" duration, the exhaust is pushing out the intake upon opening and on closing the piston is to far up in the bore pushing air back into the port. It may tolerate 220 degrees for example, but to get from 280 to 220 there's 30 degrees of engine rotation on each side of the lobe, hence me saying that the ramp would be very slow or lazy. Typical lobe @.050" durations used in the 4 cyl antique pulling engines we would see 190 on the mild side, 210-220 is pretty common and sometimes into the mid 220's on the bigger engines if they are going to run some RPM. It's typical to see 35*-45* advertised duration than .050* duration numbers. Most of the cams though for these Allis and Farmall will be between 195 and 215 @ .050" in order to work well for a pulling application, with some a slight bit on both sides of those numbers depending on if the engine is larger or smaller, carb, head and manifold limitations and RPM range. So again, in order for an advertised duration of any reasonable lifter lift say (.006-.012) (as some grinders use a different number) to work, the ramp would be very slow to get to a reasonable . 050" duration with these engines...... and by going to a shorter advertised duration, with the same .050" duration, the engine would gain torque through it's operating range. In Larrys case, the cam was passed around the neighborhood for a good reason and he's much happier (I'd assume by the wording of his post) with something Barney sent him which would have a .050" duration in the range I posted above. I know some of the low RPM cams coming from Barney were in the 195* @ .050" range and the higher RPM or bigger engines had a tad more. I'd be willing to bet that the 280 seat duration cam was around 230* @ .050", maybe even a tad more, 234* maybe. We know how well it works and how much happier pullers are when they drop to a more reasonable range, and have a faster ramp....of course pank can't tell us, he blew his engine (governer failure coupled with a connecting rod made for a 15hp per cylinder engine) with no proof of it working well and refused to show up at the dyno challenge he requested. Though he claimed to build an engine, to date no one's seen the Tennesee Stud make an appearance. |
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6351 |
OK, so other than moving my stock cam 1 tooth advance, I need to source a good cam and have it machined. Barney is backed up a year or more, the guy in NC died a few years back, Berry does not do a good job....
So who is left? or is there a source for pre-done ones out there?
Charlie
mgburchard
Marty you didn't read Larry's post did you ?
mgburchard
1800-426-2261 can craft speak with charles
