small front tires on a WD puller |
cotncrzy
Orange Level Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
Posted: 26 Jan 2013 at 11:50am |
Is there an advanage to lowering the front end of the tractor? I could loose a few pounds this way. I am going to re do the front weight bracket, smaller tires will affect my design, so I GOT TO MAKE MY MIND UP.
Edited by cotncrzy - 27 Jan 2013 at 6:39pm |
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Mrgoodwrench
Orange Level Joined: 03 Apr 2011 Location: CHICORA PA Points: 2081 |
i think we need a little more info cot...lol!
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
CTuckerNWIL
2
SF Fan
Orange Level Joined: 12 Jan 2013 Location: Iron Hills, ME Points: 431 |
3
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
I like rake.
cwhit
Orange Level Joined: 12 Sep 2009 Location: Sigel IL Points: 963 |
The answer is yes. It has to do with leverage.
cotncrzy
Ok this is what I wanted... Don't stop now! I assume with the front lower, it will take more force on the rear to lift it until it gets to a ceartin point??????
Edited by cotncrzy - 29 Jan 2013 at 6:11am |
Orange Level Access Joined: 12 Sep 2009 Points: 19585 |
Whenever the front has been dropped down below centerline, as you begin to raise the front wheels off the ground, the front weights actually start moving forward a bit making the front heavier/harder to lift. The lower it is dropped the more this has an effect.
WildBill
Silver Level Joined: 26 Aug 2012 Location: Mandan,ND Points: 190 |
Cotn , put about a 3 or 4 degree rake on it. use an magnetic angle finder place it on center of engine . Maybe between the 2 water jackets on the cylinder head . Then see where ur at. Be careful at rules etc. There is a sled in the area where I live that disqualifies over 18 inches of lift. That sucks! But it's a hook. Take care .
Allis fan for life ! B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
d17brown
Orange Level Joined: 11 Sep 2009 Location: farley iowa Points: 1668 |
i have a set of rc wheels for sale, they are 15 inch run them on my puller
phil
cotncrzy
What will fit? Is the pattern 5 hole x 4.5 or 4.75? Any automotive wheel fit? I am away from the tractor cant go measure. May be able to find something at a salvage yard, I have an old axle, with a set of 12" wheels on it, I think they are 4.5" pattern. I would like to go aluminium, and look pretty! LOL!
farmer_rob
Orange Level Joined: 11 Sep 2009 Location: N.Lancaster ont Points: 356 |
I replaced my originals from my wd45 with ones from a farmall cub. I cut out the centres out of the cub rims and welded in ones from the spare 45,s . I did this for two reasons. 1 i wanted to lose some weight. So I thought of removing on tire but was not allowed. By using the 4x12 cub they are 18 lbs whereas the 45's are 52lbs each. Lost 68lbs instead of just 52lbs. Just following rules lol. 2 is leverage just like doc said I figured it would be harder to lift therefore I would infect be further down track before she started to lift
if farming was easy everybody would be doing it
farmer_rob
I forgot to mention I have 12.6x38's on the rear
