thinking topfuel machining on 226 |
Post Reply | Page <1 45678> |
Author | |||
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
As i said once before I will say again if the cranks is welded completly with journal wire and not done with a softer wire in the radius the crank can not flex and it will have stress cracks in it after some runs and is usually found at same time the mains being pulled or broken is found. May take dye penetrant to find stress cracks but you know its cracked or had bad weld jobs to begain with if it want ring through .
Sponsored Links | |||
cotncrzy
Orange Level Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
There is a lot to learn in an arguement, if one person knows what he is talking about. You can figure out who this person fairly quickly. I have put togeather a tractor off this forum, just dig through the arguements and find the good stuff.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
mlpankey
You can get on gleasons crank welding site and they will tell you the advantages of a two wire welder and even sell welding wire kits for specific crank hardnesses. Thats how simple it is to know whom knows what they are arguing about and who doesnt. Enternet is full of information if your not to lazy or simple minded and always have to be right over on person to use it and learn from it. majority of four cylinder cranks have the two center journals down at the same time.
Edited by mlpankey - 21 Dec 2012 at 7:15am |
unstylish_
Silver Level Joined: 19 Dec 2012 Location: southwestern Mi Points: 129 |
Yes but they aren't 6"+ stroke with extremely high compression. I just think somewhere in that range is the limit of a stock bottom end, and or that cast iron composition.
mlpankey
aliis 226 cranks are forged .I do not know the compression ratio Jr. runs I know he made a comment to one that it takes building alot for others to keep him pulling regurlarly due to some reliability issues and didnt expand on what those issues where for him. In my experience issues with cranks and mains go away when cranks get welded and balanced properly by me and its not just opinion its experienced from trial and error.
Edited by mlpankey - 21 Dec 2012 at 9:53am |
Breeze
Orange Level Joined: 11 Sep 2009 Location: Ga Points: 8931 |
Politics (10 Viewing) enter at your own risk, no life guard on duty Edited by Breeze - 21 Dec 2012 at 9:49am |
Rod B
Orange Level Joined: 25 Jul 2011 Location: Peoria Points: 415 |
What is your expected turn around time at pank's cranks? If I send one to your adress will you post step by step pictures while you stroke it? |
unstylish_
So is that why this last rotating assembly didnt break? You did the welding and balancing yourself? Well, I guess when the governor weights broke on your tractor and it instantly jumped from 3k to 6k UNDER A LOAD, the acceleration was so fast and it happened so quickly, that the rotating assembly didnt have time to break, only bend..lol
mlpankey
typical machine shop answere is always two weeks to get you to leave it . doug taught me alot over the years. So inquizitive on my knowledge you follow me on all the automotive sites. Well at least your getting smarter maybe the rest will follow. Edited by mlpankey - 21 Dec 2012 at 7:30pm |
Butch(OH)
Orange Level Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3831 |
Prior content removed. For those who read it, sorry for my part in lowering the bar. We will try to add content that raises it from now forward. Edited by Butch(OH) - 22 Dec 2012 at 7:00am |
unstylish_
What did I.miss?
Rod B
So did you get your 7" stroke motor done yet spankey the keyboard commando? It's after Christmas and for a guy claiming to have all his own machine shop with a crank welder you should have something to show us.
mlpankey
Rod B
You're right, the things you show look like @$$ from torched up rims to cobbled up plumbing, balanceing work, bad crankshafts and bad welding.
Why not buy a crank from unstylish? He's got a 6 1/2" stroke for sale, wi50 has got billet rods available in about a 1 month turn around. He's shown that rods will clear with ease so you won't have to think for yourself. Piston makers are short lead time, Power Bore and Darton are close lead time for cylinders. There's no reason you can't have a motor for some winter pulling. For a guy with no skills to do things for himself this seams like your best opportunity to show us you're not a keyboard commando. Edited by Rod B - 09 Jan 2013 at 11:59am |
mlpankey
unstylish cranks on loan to wi and you know what i found wrong with it just in pictures. yeah pistons and sleeves arent a problem . yeah we can get several going before one gets finished in wi.
Rod B
Silly wabbit. The crank is mine. You were posting that it was Marty's and now you think it's unstylishes. But you change your stance quite often when lying.
Edited by Rod B - 09 Jan 2013 at 2:57pm |
mlpankey
Oh well you got a nasty looking crank job. But it should be fine for a couple of years it will take that long for wi to get it built for you.
Rod B
I'm a lot like Kendak. To nice of a guy to badmouth someones work so I lied to Wi and told him I bought the crank out of Mi. It came from pank's cranks. One of your outhouse employes sure messed it up. I won't have to worry about it breaking. That head and cam you sold me won't make enough hp to hurt anything.
Morral of the story is to stay away from pank's cranks. |
unstylish_
All kidding aside Pank, you should just buy my crank. Im moving up to a LLSS, and I just dont need it. Ill make u a deal on it. More money does not equal a better product. Any fool can blow up a bulletproof motor, but you wont get a better or a cheaper one to experiment on. Its still next to my dresser, like you noted earlier. Ypu need not agree nor disagree with me. There it is, on the table.
When it comes to tractor pulling, the smartest move I made was calling T.I.T.S TRACTOR INDUCTION TECHNOLOGY SERVICE in Wisconsin. Since they did the head and manifold for my little WC, its been an animal. He can do the same for you. From liners to rods, heads to carbs, anyone familiar with T.I.T.S, loves them. |
mlpankey
We get better than 148 cfm out of the head. You remember asking about that number on yt. If someone wants me to build one if yours has no purosity showing rings through and passes a die penetrant test. Then i would use it in someones build. As for me we are going bbc.
Rod B
When are you going to build an Allis for the Allis forum? Admitting defeat by useing a Chevy. At least all the parts are boughten rather than built yourself. If you bolt it togather it might run.
Those poor flow numbers must have came from panks cranks to. Good thing TITS fixed it up so the motor could make some power. |
mlpankey
I build allis and have built allis for the forum. When are you and wi going to campaign one for the forum. Its a allis pulling forum not a ih moline or case forum. A fellow on here is destroking a 426 to run that 370 ci class on here. So he should be taking space on here that a case and moline uses up but he dont much.
Edited by mlpankey - 09 Jan 2013 at 8:33pm |
unstylish_
The old head was 148. Not a bad number for what it was. It made decent power on my old 360 inch motor. Everything was done well, just not as well as the new one. I got the new one and manifold from TITS. DYNO PROVEN POWER.
mlpankey
Didnt it break first time out seams mopower was eluding tothat over on yt.
mlpankey
Unstylish if that induction system woke up a small cubic inch motor just imagine what it would have done if you had stayed at 360 cubes or even went bigger.
Rod B
And we thought you might do something to show us you weren't a keyboard commando. There's others with a 7" stroke, ask Jeff @ Murphys. Why can't you do it pank?
unstylish_
I popped a head gasket with the old head the second run out when I built it. Still got a podium finish at NATPA that weekend. I messed up the head gasket when I made it.
Since I needed to change the head gasket anyway, I had a new head built more suited to my motor. The old head and manifold is actually quite nice especially for a mph tractor. Yes, a large inch motor would be fun. But, for what I pull, I just dont need it. |
mlpankey
if it can be it will be done by a southerner like hayden or myshelf. cause theys to many 6.5 cranks laying around up north forsale.
Rod B
148 cfm isn't to bad unstylish. Pank's was only 143 at .400.
Half of what T.I.T.S. can get. No wonder pank can't figure out how to make power on his own. |
mlpankey
