successful & reliable WD puller |
Post Reply | Page 12> |
Carl(NWWI)
Orange Level Joined: 13 Sep 2009 Location: NW WI Points: 948 |
Posted: 06 Nov 2012 at 10:03pm |
I got an idea.... build a WD with a Gleaner E, 4 1/8 over flat top pistons, port and polished head, barney cam, carb from treadwell carb in new York, pertonics electronic ignition, pertronics flamethrower coil, E3 52 plugs, governor override cable, and pull the damn thing!!! 110 race gas and premium mix. 60 peak hp, 52 at rated, and 485ftlbs torque, that was with a bad rotor in distributor. I built it when I was 15. First engine I built too. Not that hard. Brought home more trophies then I know what to do with. Pull it, have fun, make friends, and get along.
Carl. If you need proof I have pictures and videos. |
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6351 |
Well, show us some pictures and videos!
Charlie
wi50
Works pretty good doesn't it. I got a similar one except for a quench piston and the batch of cams was takeing forever to get back here so I put a stock one in timed correctly.
Maybe my big winter upgrade will have to be to a piece of wire as those zip ties fail at just the wrong time. Mid mount 12v beer cooler would also be handy in place of the original battery box. Changeing the cam requires more work than I'm willing to put into it. |
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
I was under the impresion that when everyone designed the front weight bracket its to hold their favorite beer cooler as well as weights .I guess now thats just the superiorty of southern pullers to think of it also when making a weight bracket. We southern pullers tend to think of everythng.
Rod B
Orange Level Joined: 25 Jul 2011 Location: Peoria Points: 415 |
Once again superior design from the north. The cooler is partialy shaded from the sun by the gas tank. It's in close proximity to the driver for easy reach. Foot rest doubles as bottle opener for the high class stuff. The battery is also closer to the ignition system for less voltage drop.
How would one get beer from the front without getting it themselves, or (assumeing they have friends) asking a friend to grab one. It could get lost in transit. On those long hot days when driveing your tractor to the pull it would be a pain to stop, walk up front and grab more for yourself.
Mid mount is a much better idea, easy for both driver and crew to access, shaded, and one needs not leave the seat to get another. Rear platform holds recycleing bin and after enough those fenders make dandy resting places.
Superior by design from the professiona weegie. Not a bad idea pank, but like all your other ideas there's much better ideas out there.
Carl(NWWI)
[TUBE]6NADK7vymkU&list=UUqKkG0zoSWkdD2Uosw-U5jg&index=6&feature=plcp[/TUBE]
[TUBE]-0d2EYuLRso&list=UUFHUFAlMspVqFVCuBmfa9Mw&index=45&feature=plcp[/TUBE] |
Carl(NWWI)
Now rather than bickering like a bunch of school girls, figure out why my 190XT puller makes the chirp....because id love to know!
[TUBE]4rdtL9fp5MA&feature=BFa&list=UUqKkG0zoSWkdD2Uosw-U5jg[/TUBE] Edited by Carl(NWWI) - 07 Nov 2012 at 5:07pm |
mlpankey
Rod your forgetting about the gals in daisy dukes handing cold beer to us. Plus we like to share your battery box just isnt big enough
mlpankey
Carl(NWWI)
Oh, Thank you. Wasn't sure, that clears it up. Well duh! But why???
Carl(NWWI)
Yes it does, works great! Yeah, its to bad it broke, you had a good run going! Be neat to see how we do against each other on a good clay track. |
AC200Puller
Orange Level Joined: 04 Dec 2011 Location: Wisconsin Points: 774 |
Hey Carl I still think you need bigger valves to let that air flow. I think the windmill is blowing into a block wall. At least that is where I would look, I am running a similar setup and the difference is in the head.
Orange Level Access Joined: 12 Sep 2009 Points: 19581 |
What is the turbo?? sounds like it's trying to sneeze out the intake. A custom intake wheel and compressor housing map slots??
Carl(NWWI)
Yep, I agree. Charger is pushing more air then what it can take.
Carl(NWWI)
Was a 3lm 466, was real bad with that one, now its a garrett off a 250hp IH 466 truck engine. 57mm x 75mm compressor t4 garret a/r .60 compressor a/r 1.15 turbine |
wi50
A little more intake valve and a lot more exhaust valve.
These heads are a mess and the exhaust is to restricted to drive the charger hard enough. Your boost will drop which will be a good thing. With head work and that 3lm-466 back on there's another gear to be found. Ever check the exhaust pressure and intake pressure to see the relationship? If you get a chance sometime swing out. Christmas came early and I bought a big piece of billet alum carved out with combustion chambers, 2.5" titanium intake valves, Jesel rockers ..... though it's got sparkplug holes and fits a IH block. Edited by wi50 - 07 Nov 2012 at 6:43pm |
WildBill
Silver Level Joined: 26 Aug 2012 Location: Mandan,ND Points: 190 |
Carl , I'm an isx cummins tech and we experience chirping issues when the waste gate actuators were not in sync . So where am I going with this at certain peak Rpms almost like floating the valves the air will come back at an instant and dead head the incoming air causing the compressor wheel to give a momentary stop and go but in milliseconds time frame. ( chirp). See this on our Taylor dyno at time to time and a truck will hop pretty good on the dyno. May change housing ?http://touch.bismanonline.com/air_compressor_d_45/# Or like the other fellers say get the cylinder head opened up and exhaust ports. Like constipation and asthma theory . Lol. When I drive my beer holders are on my custom orange helmet . Closer and no one will steel them up grade option is Double barrel straws reload is hottie whisker biskit in daisy dukes with boon and crocket rack .
Allis fan for life ! B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
WildBill
Lol not sure why it posted a link?? Lol. Your tractors are nice Carl !! Good trophy collection
Carl(NWWI)
Thanks Bill! Have alot more trophies then that, pictures is a couple years old. But yeah, similar to compressor stall, stops spinning / forces air back out intake and makes the flutter sounds. Thanks for the info.
Marty, we've talked so we are kinda on same page, had to see if your buddy could get it. but I agree, if we could get that 3lm back on it, it would be nice, seemed to have more power with it. Ill definitely have to come check it out. Might have picked up a 301 head from tech school, ill bring it up, other wise ill pull the one on mine, or go to downing...lol either way, them heads are a mess. Wish I could tell you ratio between boost and back pressure. But gauge for back pressure wont read correctly. |
KGood
Orange Level Joined: 17 Nov 2009 Location: Logansport,IN Points: 955 |
Carl,those were good hooks on the WD and a good point.
AC200Puller
Carl I am running 45-50 under heavy load on intake and 40-45 on the exhaust side seem to be working ok would like more hp but then the reliability goes away, You were at most of the pulls when I was going though those growing pains. LOL. And some are caught on video.
Carl(NWWI)
Lol. Heard that Dave! She's on fire!!! Haha. With the 3lm I was running 40-45 boost, with smaller garrett its around 30-35. Call Scheid and get a .500 roosa! She's run then!
Carl(NWWI)
Heres a video of it with the 3LM, she sounds real bad with that charger, i was embarrased i even pulled it like that! haha
[TUBE]PTEkg1Vlv1Q[/TUBE]
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4781 |
Larry W.
Silver Level Joined: 07 Nov 2010 Location: Luck, WI Points: 278 |
Carl, you need a 180 exhaust housing to turn your 3lm adequately at your rpm
Carl(NWWI)
Dont have a problem spinning it, just too much boost for engine to use.
Larry W.
Ok....
Carl(NWWI)
Get confused?
Larry W.
Not at all, just trying to give you some help Carl, but you got it under control.
Carl(NWWI)
I can understand a smaller housing if I was having a hard time spinning it, but spinning it is not the issue, the few times I pulled it with that charger I never fell under it. Granted my clutch was slipping, but seemed to have real good power. Im just giving the engine to much air that it can't take, so its coughing it back out the inducer.
