wheel wieghts
cobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cobra Quote  Post ReplyReply Direct Link To This Post Topic: wheel wieghts
    Posted: 12 Sep 2012 at 8:19am
i have a d15 series II  i think it has combine wheels on it. with winter sure to come  i'm wondering if wheel wights can be put on or  is loading my tires the only option
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2012 at 10:00pm
I would think you could find some that would fit.  Are they 26 or 28 inch rims?  That will make a big difference.  I think there are a lot of "universal" weights out there, especially for the 28" rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2012 at 10:31am
Combine rims on one of the D15II units I picked up have no means to attach weights and I will fill them with an RV mix when I mount the loader.
Guess a guy can always weld something in-place for mounts on the rims, then your options for weights will be much better.
You can also make brackets off the side of the drawbar bail assy. and use suitcase weights . . . . .
