Going to look at a 444 baler.
shattercane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shattercane Quote  Post ReplyReply Direct Link To This Post Topic: Going to look at a 444 baler.
    Posted: 07 Sep 2012 at 7:28am
 I'm headed out tomorrow to check out a 444 wire baler, can anyone tell me if they are a good baler and if there are any parts that were failure prone so I don't overlook any potential issues? Also if anyone has any history of the 444's I would appreciate any additional information or suggested value.
Thanks.
29 L Case, 37 CC Case,40 A-C allcrop 40, 43 B Allis Chalmers, 50 DC Case, 54 WD-45 WF, 67 190 Gas
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 7:51am
We have a 444, baler without the kicker, and love it.  We don't use it for a ton of bales, maybe a hundred a year, mostly just to play.  Our will mis tie on the first few bales untill everything get shinned up again, one of my knotters is not quiet right.  I have been looking for parts, they are available, but not plentiful.  I just have never pulled the tirgger on buying them since it really isn't a huge problem for us.  As for the general baler, I think it is pretty bullet proof, just a good solid work horse.  Make sure it is all there, including the wheel on the pickup, and the driveshaft.  Check out the shear pin on the front flywheel, make sure there isn't a lot of play in it, otherwise you will have a hard time holding pins. Make sure the needles are straight and not bent.  I would hand crank it through one tie cycle and watch eveything dance correctly, before I power it through one.  Then if possible watch the current owner bale something, but that might not be possible right now.  Just beware of rust in the bale chamber, and look for wear on the ram tracks in the front.  If they kept it in the shed, and kept oil on the tracks, and grease in the pivot points, you sould be good.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote shattercane Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 12:38pm
Thanks Orange Blood,
From what I've heard this baler has not been in a shed so I will definietly check for internal rust to see how bad it is. If they were easier to come by the price might be a little easier to swallow, but 2500 seems a little steep to me. Thanks again for the reply
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 6:47pm
Thats very steep! ! $750 would come to mind first
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 10:58am
So did you get the baler ?
We have tow string tie and we like them, only use one.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 1:53pm
wow! I paid $150 for mine,string tie shedded and in decent shape
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
Post Options Post Options   Thanks (0) Thanks(0)   Quote shattercane Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:07am
No, I passed it up. I tried a lowball but it was unsuccessful. I will continue my search but if anyone knows where any model wire tie allis baler is for sale please let me know.
Thanks.
