Guess what is missing in this picture
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: Guess what is missing in this picture
    Posted: 23 May 2012 at 8:49pm
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 8:59pm
I only see 3 of the 4 bolts that hold the 2 halves together. Is there a needle under the float?
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:06pm
THE TRACTOR !! sorry, I am going to bed now.
I used to be young and stupid, now I am not young anymore.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:09pm
GAS!!!!
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:09pm
The rest of the tractor .
 Are yea saying you got troubles with carb flooding?
 Doesn't look like that theres the finger to press against the needle..
Edited by JC(WI) - 23 May 2012 at 9:11pm
CAdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:10pm
and brian, too, apparently.   zzzzzzzzz.
52 CA, 41 B and a little B1    oh, yeah... and an 8N ford snuck in there, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:15pm
I can't see the picture that well without ma' glasses, but the glassbeader, cause' that carb needs a good blasting to clean the rust and debris outta' fuel bowl and the rest of the unit...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:20pm
Whats missing is the carb that belongs to that plastic venturi. I put together a carb for the D17 for a pull on May 12, and this is why it didnt run that good but still pulled 297 ft.
This is what it looked like when I took it apart
And this is what it should have looked like.
So I guess a M/S carb will run without a venturi.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:43pm
That carb is for a D17? I have the same one on my little 18hp MI John Deere! LOL
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 6:35am
Doesn't the first pic show a brass venturi? The pic in your initial post that is.
Edited by Lonn - 24 May 2012 at 6:36am
Wink
I am a Russian Bot
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 6:39am
It's been awhile since I rebuilt a Allis carb. Where do you get plastic venturies at ? Are they for pullers ?
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 7:41am
I also would like to know about the plastic venturi ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 4:46pm
Lonn; Ya the first pic shows the brass venturi in the parts carb. I got the plastic venturi from Barney Taylor, they were used in the 175 gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 7:12am
They will run without the venturi in them. Not good, but they'll run! Yeah, that first pic threw me also (from what I could see without my glasses) cause the venturi is in the carb. Polish up that stock venturi and it'll move some air.  Clean them fuel bowls up and get rid of the crud. That'll make it stop!
