wd-45 plow / disc question
cbuttre835 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Topic: wd-45 plow / disc question
    Posted: 17 Mar 2012 at 7:41pm
My dad is rebuilding the motor in a WD-45 gas.  he is using one of the A&I products 4 1/8" overbore kits with flattop pistons.
He has a 3 bottom plow snap coupler plow, it looks like 3 12" bottoms (measuring perpendicular to the direction of travel, anyway).  It is an AC "slat wing" plow, if that helps.  Will it pull 3 bottoms?
Also, how big a disc will this tractor pull?  I'd like to get one of those snap coupler discs, I know where one is in a fence row, but it's about an 8 foot.  It's one of the ones that looks like its made of angle iron.
Thanks in advance...
C w/ 3rd gear out
D15 II factory 3 point
WD (no motor!)(parts for sale!)
WD 45 wide front
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 7:53pm
  we pulled a 10' wheel disk with a 10' spike tooth behind the disk was  no load  gave wd a nice load  like to see the gov work
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:06pm
   A WD45 will pull a 3-12" snap coupler plow or 8' disc all day long in 3rd gear.
http://www.rumelyallis.com
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:30pm
I pull three 14's in heavy clay with my 45. eight foot disc is fine.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:58pm
Dad pulled a 3x16 in black dirt 3rd gear. He also pulled a 12 1/2 foot 200 series AC disk with 18" blades. The disk was more of a load than the plow.
Wink
I am a Russian Bot
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 6:36am
Price bearings for that disc befor buying it. Most likely why it is setting in fence row. MACK
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 7:41am
Our WD45 is above stock hp and plays with the 3 bottom sc plow(14 or 16s) and also the 12 foot AC transport disks. Stock 45 should have no problem with any 3 bottom or 8 foot disk in most soils as that is what they were designed for.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 8:19am
I pull 3-14"s and 3-16"s plows with WD45 tractors and 10' disk and I think your WD will play with a 3-12" plow and 8' disk.
