WC cast Iron oil pan
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: WC cast Iron oil pan
    Posted: 05 Dec 2011 at 10:01pm
Guys, I need some info here, what time frame did AC use the cast iron oil pans on the WC's? I wondered if they ever used them in 1937?  Dave.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:34am
David , I had a 34 with cast iron pan. Don't think they used them much longer after that. MACK
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 7:11am
I do not know for sure but perhaps they were used during WWII.
Good Luck!
Bill Long
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 7:12am
Dad has a 1945 WC with a cast iron valve cover but I don't know if was a transplant. It does have the steel rear end. Actually I have most of the tractor now, in pieces and on the long to do list. Never have seen a 37 WC with any cast iron oil pan or valve cover.
Wink
I am a Russian Bot
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 8:03am
I think they were only used in 34 and 35.
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 10:28am
My '35 had one on it, but it was cracked. I put a steel one to replace it.  I think they returned during the war, but not sure.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 11:17am
i had a 35 with one and I have a engine out of a 36 that has a steel one . Scott
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 9:12am
As far as I know they were used in '33-'35.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
