1940's AllisChalmer
Kylie25 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kylie25 Quote  Post ReplyReply Direct Link To This Post Topic: 1940's AllisChalmer
    Posted: 03 Dec 2011 at 11:40am
I have a 1940's AllisChalmer, it is Model A with no serial number. It does currently not run, but needs minor work. (new battery, oil change, ect.) I would like some input on what someone would suggest it is worth??
Thanks!
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 12:01pm
If you have an Allis A, its more likely 1930's. Someone I'm sure will tell you where to find the serial number.....I'm not familiar with A's to tell you. As far as a battery you need a 6 volt battery and it should be Positive + ground. Make sure to hook it up right. Make sure it wasnt changed to 12v before buying a battery though. If it was changed to a 1 post GM alternator or something like that is possible. As far as worth, we'd have to see pictures to really give an idea on value. I'd love to have one.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 12:02pm
Going to need a picture of it to start with. Why is there no serial #? It should be on top of the tranny next to the shifter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 12:05pm
Oh yeah....forgot to say, Welcome to the Forum!
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kylie25 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 12:41pm
Thanks! & i have uploaded a picture. i don't know a lot about this tractor. It was  my great grand fathers'.  It use to run about 2 years ago but has been sitting since, it also has a snow plow attached to the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 12:43pm
if you go to something like photobucket you can load the pic and then load it to here or email me to me and I'll post it up for you....its kinda of a pain to do. fxshovelhead@live.com
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kylie25 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 12:48pm
I sent the picture to your e-mail.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 12:50pm
   Doe's the tractor have hydraulics ? If so, it most likely is not an A.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kylie25 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 12:54pm
It does have hydraulics to lift the snow plow, but on the tractor it does say that it is Model A.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:07pm
Its an Allis B with a Henderson loader....I'll have the pic up in a few minutes
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:08pm
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:09pm
Great little tractor the B is....get it running and have some fun with it.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:11pm
Only thing I'd be worried about is I dont see a muffler, or much of a stack sticking up and it doesnt look covered...first thing is to see if it'll turn over. I'm sure there is someone here close to you that can help with it.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:13pm
   Yep, it's a B. Tire chains and the loader are a plus !
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:13pm
I hope this tractor hasn't been converted.  A "working tractor" should be converted.  A show tractor should be left as original as possible.  Just my opinion, that's all.
Edit:  Ah.. it's  B - not an A.  Nevermind.
Edited by DougS - 03 Dec 2011 at 1:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:16pm
   Huh ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:20pm
Converted to 12v I think?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kylie25 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:27pm
It does take a 12v battery. Any opinions on what it would be worth or a year?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 1:37pm
   Click on the link to see where the serial number should be, this will let us find the year: http://people.clemson.edu/~wsmth/SNLocat/ACSN1.htm
   As far as worth ? If not running. maybe $500
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 3:56pm
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 3:57pm
I see X4XX051 ....I cant read the digits that I placed X's for....anyone else see what I dont?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 4:45pm
There are lot's of B's out there but this is the only one YOUR grandfather had and I hope you think about that factor! If you sell it it won't bring much in the condition it's in .
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 5:48pm
Well said....I'd love to have my grandfather's D15D
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2011 at 8:57pm
   Kylie, your B is a late 1940 according to the serial number.
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 6:43am
Where are you located?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 8:06am
Do I see an underhood muffler with a can on top?
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 9:04am
I'm still kicking myself in the rear end for not finding the money to buy the WD that my grandpa farmed with, it wasn't his it belonged to a farm he shared cropped. It was the tractor, 3 bottom sc mounted plow, and a 2 row corn snapper (picker without the husking rolls.)
Edited by stray - 04 Dec 2011 at 9:07am
1969 190XT series 3
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 9:16am
I would also think long and hard about selling it.  Not very many of us have anything from our great grandfathers.  I wish I did.  Having something that he used is much better than a few pictures on the wall which is all I have.  Later in life you may wish you had it.  If you don't have the means, funds or time now then just get it under a roof and let it sit until the day comes that you do.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 11:23am
And the other thing, Kylie-  it may not be a BIG tractor (in comparison to a WC, WD, or D-series)...
but it's big enough to pull a family car out of a bad 'stuck', and the Henderson loader on there will make a weak person strong... moving landscaping materials around the yard, put a chain around it and carry heavy stuff, rip out unwanted brush and thorns... it's a great general-purpose workhorse, and it's compact and light enough to maneuver around a smaller yard.
Hey guys-  take a really close look at the operator's station.  I see the shifter, and I see another (taller) lever with knob...
Now, it MAY be that the taller lever is a control for the hydraulics... but what IF Kylie's report of saying Model A... is actually  CA...  and someone put a B wide-front on it for the loader???  Might this be a CA?
Edited by DaveKamp - 04 Dec 2011 at 11:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2011 at 12:47pm
Dave  It's a B all the way-- B fenders, no power shift wheels, B seat back.
This page was generated in 0.046 seconds.
