connecting rod orientation
mp38b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mp38b Quote  Post ReplyReply Direct Link To This Post Topic: connecting rod orientation
    Posted: 23 Nov 2011 at 6:57pm
I have a pile of mix and match rods and caps. Can anyone help me with rod orientation ? Which cylinders have the wrist pin bolts pointing towards the cam?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mp38b Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 6:59pm
I suppose that knowing that the tractor is a '38 B is helpful.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 7:58pm
Some one can proabley set you stright  but on my 49 B  2 went one way and 2 went the other. The way i done was after fitting rod on piston  put piston in and slide down and you can tell which way it needs to go.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:01pm
Don't know if this helps but it says the connecting rod is offset and the long side of the offset should be away from the nearest main bearing. Not sure if the wrist pin bolt matters?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 8:04pm
OK, the other book says replacement rods are not marked and the pin clamp screw should face the camshaft.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 9:23pm
That is the oranitation an the 201 & 226 engine, but on the B they are different. 2 face the cam and 2 face away from the cam to offset the bearings. Bob
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 11:11pm
From the manual.
Numbers 1
and 3 have the long part of the bearing
toward the flywheel, and Numbers 2
and 4 have the long part toward the
timing gears.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 5:53am
Would a picture help?
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2011 at 7:12am
Listen to Dick L he knows his stuff!!
