wc still won't start
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: wc still won't start
    Posted: 05 Oct 2011 at 6:07am
my wc will not start with the crank. pull starts and seems to run fine. impulse spark is good. frustrating.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 7:07am
Try .020 gap on your pluds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 8:15am
I did try that. no difference. Really not sure what else to try. I'm thinking I will pull the carbon and clean it out again. How do you time these old ones? So far, I just lined up tdc and number one on the fire mark on the flywheel.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 8:34am
GH, I had this situation once on a WC and once on a B.  Each time it turned out to be the plugs.  I use new plugs in engines I have rebuilt, and I blast plugs in engines that need rebuild.  I know lots of guys say blasting will ruin the engine, but I use the fine grit that is recommended for this task (I think it is aluminum Oxide) and blow out the plugs well afterword.  "Playground Sand" is definately bad for Plugs.   I had a ford that acted the same, turned out to be the condenser.
The only other thing I can suggest is to try a couple of different timing settings on the mag.  When you have the fire mark at TDC, check the mag to see that the rotor is at the timing lug in the mag.  One tooth off in the internal gears could do this also.
Edited by Dave Richards (WV) - 05 Oct 2011 at 8:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 8:37am
well, I have a fmk mag. it is a little different than the j. I am not sure what the timing lug is. I'll try swapping out some parts and see what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 9:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 10:03am
yeah, that's the fmj mag. mine is different. I will take a closer look tonight to see if I can see something. thanks for all the help. I want this to run right do bad
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 10:47am
Assuming you have non resistor plugs and wires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 10:50am
autolight 295 not sure on the wires. good spark. runs when pull started
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 12:08pm
As far as checking timing the fire line is to check with a timing light. If you are just inching the engine over a tiny bit at a time when number one plug fires on the compression stroke you want to see the TDC or CENTER line in the inspection hole at that instant not the fire line. If when checking this way you see the fire line you are 30 degrees off advanced. The instructions for installing the magneto on the tractor using the fire line is to let the magneto engage the slots which no can do at TDC.   When installing the magneto at the fire line on the flywheel the flywheel still has to turn the 30 degrees to trip the impulse to fire the plug. After the engine starts the fire line will then be in the inspection hole because of the mechanical advance.
Edited by Dick L - 05 Oct 2011 at 12:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 12:15pm
Dick, so according to what you say I am doing something all wrong. I am finding tdc and then centering the fire line in the inspection hole at the bottom of the bellhousing. Then, I install the mag with the rotor pointing at number one on the cap. If this is wrong, please let me know what I am doing wrong. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 12:35pm
I think your making to complicated. Myself, I check the magnetos in a vice. I install the points cap using the marked small beveled tooth up and the proper letter on the fiber gear, C normally over the marked gear. I make sure all plug wires are firing. I then snap it over until the fourth plug wire sparks,(which would go to number three cylinder) and number one is ready to spark/fire.  I then put a piece of tape on the impulse so it can't turn backwards to re fire the number four terminal. The rotor will be where it needs to be if it is firing the plugs as it snaps over. I turn the engine over until I first feel pressure on number one plug hole. I don't worry about any fire line as it would not quite be to the inspection hole yet by a tad. I then install the magneto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 12:45pm
That's the same as I am doing except I line up the fire mark. I think it is timed pretty good. Just don't know why it runs so good but won't start off the crank.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 7:53pm
Not familiar with FMK does it have the proper lag timing on the impulse coupler for a Allis?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 7:57pm
yes it does. I'll take a couple pictures next time I have it apart.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 8:05pm
You might try this, when you have it running try moving the mag a little one way then the other, to where the engine sounds the best.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 8:46pm
My WC has started hard since I got it back, would pop right off with a pull. It wouldn't idle worth a crap but seemed to run fine at higher rpm's. I've been trying to figure out if I have a vacuum leak or a fouled idle circuit in the carb. The other day I messed with the timing a bit. It seems like I run out of travel and have the best timing with the mag tipped against the throttle rod. It will now idle much better and start easier. I am going to have to check the timing out from scratch cause the guy that put the engine in for me was a deere guy and had never worked on an AC.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 9:24pm
Ctucker, being a Deere guy, he probably set it up to run on 2 cylinders, but which 2. Bob
klyant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klyant Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2011 at 10:08pm
Do your plug wires have a copper core? if not you will have a weak spark.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2011 at 8:41am
Hopefully I will have time this weekend to work on it. I have a few ideas to try. Thanks, Jesse
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2011 at 9:13am
Question for DickL..  Is there any chance the mechanical advance on this mag is stuck in the advanced position?  Might explain why it starts when pulled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2011 at 9:18am
answer... I checked that also. That was my first thought. The key was broken in the impulse mechanism. Once I fixed that, I thought I was home free. It did solve one problem, but not the hard starting.
SandburRanch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SandburRanch Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2011 at 11:19am
What no tractor owner wants to hear. The no start with hand crank but starts by pulling and runs fine is an indication of low compression.
This same thing with electric crank has been happening for years. As a tractor aged the original 6 volt systems had their batteries replaced with 8 or 12 volt batteries and all was well for awhile with the faster cranking speed. And then as operation hours increased the 12 volts failed to crank fast enough to start and they had to be pulled again to start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2011 at 11:21am
Sure, anytime you have something mechanical there is a chance it would stick or not function properly. Pulling the tractor will do at least two things that cranking will not do. #1 would be the armature is spinning faster and would over come a slightly weak field. #2 would be that the engine would be turning over at a faster speed causing more vacuum to draw fuel into the firing chamber. One thing of many that (can) cause a tractor to start hard when hand cranking is when the space between the main jet and the discharge tube has crud in it. That space is where the engine gets it first gas to pull into the firing chamber that does not have to be sucked thru the tiny main jet. When a tractor sets it is also where the gas can turn into gummy shellac making that space smaller. It is also a space you can not clean with the off the shelf spray cans of carburetor cleaner. It can be scraped out with small dental pics or small drill bits used by spinning them with your fingers. Best not to use a power drill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2011 at 11:28am
I do not think it is low compression. I will check it to make sure though.
I think I will give it a shot of ether and see if it starts then. That may point me in the right direction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2011 at 12:23pm
Didn't mean to point to low compression although it would be something to check if you have not. What I was pointing out about the more vacuum with the engine spinning faster was that it could draw fuel to start all the way back thru the main jet.  If you put a coffee stirring straw in your mouth and pinch your nose shut and try to breath thru the stirring straw you would find it hard to get enough air to breath. If that area between the main jet is not completely clear it will not hold enough gas for the slight amount of vacuum from cranking a 1/4 turn to start the tractor. The jet is small enough that you do not get free flow in any amount thru it. It has to have ample vacuum to draw any amount of gas thru the jet.  I am not saying that it is your problem. I am only saying it is one of many things that can cause hard starting when hand cranking that can or could  be overcome by pulling the tractor. Just something to ponder.  What works for me may not work for others but, I try to assemble all the things that could cause the problem  that I am having in my mind first and then go at checking one possibility at a time and make sure it is not the problem before checking another possibility. Sometimes I find the problem in something that I have checked more than once and somehow missed. I am very sure of myself that I can find and fix any tractor problem I am having.  I am not so sure of myself to think that I would not have missed something the first or more times I already checked if I have not found the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2011 at 12:33pm
I agree. That's why I am going to pull the just rebuilt carb off and do it again. lol... It can't be anything major. It runs so good. Bringing home an Allis trip plow for it tomorrow.
This page was generated in 0.184 seconds.
