8070 with 426 Engine problems |
Post Reply |
dmpool
Bronze Level Joined: 31 Aug 2011 Location: Westfield, ND Points: 1 |
Posted: 01 Sep 2011 at 9:18am |
This is my first time using this site, but I have enjoyed all of the info being shared. I recently purchased an 8070 FWA, and now it appears the head is cracked as there is coolant coming out around the #3 injector. Any insight on the diagnosis, or possible cause? THe engine was supposed to have been completely gone through last fall. Thanks!!
Orange Level Access Joined: 12 Sep 2009 Points: 19520 |
Bad or weak casting......things like that happen sometimes...life goes on anyway.
Eric[IL]
Orange Level Joined: 14 Sep 2009 Location: Illinois Points: 485 |
My 7060's 426 has a 5" weld near the top of the block, just under the head gasket area on the right side near the back of the engine. Who ever welded it did a good job cause its been that way for years and never leaks. Gibson City, IL AGCO dealer has (or had) a reconditioned 8070 fwa with a cummins 8.3 swapped in place of the 426. I viewed it about 3 weeks ago. The fit was excellent. Perhaps that could be a solution if you can't get your 426s head replaced or fixed.
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
There isn't a sleeve or cup around the injector with coolant around it on that engine? I thought I read where someone else had coolant leaks around the injector and it was a sleeve leaking.
ac45
Orange Level Joined: 14 Sep 2009 Points: 395 |
Head swap is not a real big deal.
allisrutledge
Orange Level Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1352 |
There are copper sleeves under the injectors on the 301 but I can't say on the 426.If the injectors are tight you should have the head checked. Scott
allisrutledge
Welcome to the site.
Hurst
Orange Level Joined: 11 Sep 2009 Location: Midway, Ky Points: 1201 |
99% sure the 426 has just copper washers, not sleeves. I had a 301 that began acting like a blown head gasket and it turned out to be a bad injector sleeve letting in coolant. I remember someone saying that the 301 and 200 were the only ag engines allis used the sleeves on. Hurst |
1979 Allis Chalmers 7000
5800 Hours |
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4768 |
correct. no copper sleeves for injectors on any 426. 2900 mark II engines got the new design cylinder head for improved coolant circulation, which included the injector tubes as well. A good 426 head should not be too hard to find. Heck, there's probably three laying around here. Too far away to do you any good! Ed.
Post Reply | |
