PTO for HD5 |
MB54
Bronze Level Joined: 12 Jun 2011 Points: 2 |
Posted: 13 Jun 2011 at 10:05pm |
My pto I beleive is the same as the pto shown in the pictures, the gearbox type. I have the connecting spline shaft and the linkage, the shift lever mounts by the loader controls.It is stored in a freinds barn and I can't get to it for awhile to take a picture. I have your e-mail and will get back to you.thanks Not sure what it is worth.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4370 |
By some miracle the bolt pattern for mounting pto's and such were standardized on AC Cat and IH crawler tractors.So pto from any other tractor make of similar size would bolt up but the drive shafts would be different lengths,and who knows what speed they would run at.Ray
Tad Wicks
Orange Level Joined: 27 Mar 2011 Location: Shandon, CA Points: 2160 |
J You have to consider what the PTO is to be used for, as Derek said the one he has looks as thought it reduces and reverses both speed and direction to that of a wheel tractor PTO (540rpm CW), the next picture down, the output is engine ''RPM'' and ''CCW'' which is to fast and opposite that of a wheel tractor PTO, but just what you need for a BeeGee pump and is disengaged with the master clutch . BTW the bolt pattern looks the same as D4 Cat but I am not certain. Tad
Edited by Tad Wicks - 13 Jun 2011 at 4:19pm |
LouSWPA
Orange Level Access Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24033 |
OK, looking through the parts manual, I believe the PTO that Derek shows first, is one of two PTO's for the HD5, and turns at 539 RPM w/clockwise or counterclockwise selectable. It should come (as shown in parts manual) with shift linkage to operators station.
The second post w/pic that Derek posted also shows as a PTO option, turns at 963 clockwise. I don't see any means of disengagement, appears to be direct drive. It looks like the power pulley, if used, is driven from this PTO shaft This one seems to me should be possible to fabricate from a WD PTO shaft, or something like that, but may run too fast for use
Edited by LouSWPA - 13 Jun 2011 at 4:05pm |
I am still confident of this;
LouSWPA
Looking at all the pics, it seems to me that a PTO drive would not be real hard to fabricate. Looks like a spline coupler, shaft w/spline end, carrier bearing and carrier bearing plate. One would need some dimensional data, no of splines and diameter, shaft length, etc.
What's not real clear to me is how/if PTO is disengaged.
JHanson907
Bronze Level Joined: 02 Jan 2011 Location: Alaska Points: 18 |
Derek - how are you? Haven't heard anything for some time. Are you still interested in parting w/ your PTO unit? Does it appear to have a clutch or some other disconnect?
JHanson907
I am interested. How much are you asking and can you send me some pictures? This is my regular email: j.hanson32@yahoo.com
Thank you for the message!
MB54
I,m in Illinois and have a HD-5 PTO and accessories for sale.
derekhopkins
Bronze Level Joined: 11 Sep 2009 Location: Australia Points: 26 |
I saw a photo of the back of a HD5 with a PTO. See here.
Now this looks like a straight through drive whereas mine has a reduction box. You may need to investigate further depending on what speed you need.
derekhopkins
a
JHanson907
The belt pulley would slip over the PTO shaft, and may be something I could use (if I can get my hands on the PTO!). I'm looking at it now. Thanks for the heads up!
JHanson907
Derek - is this something you would like to sell? If yes, a photo would be very nice. Don't see the distance as an issue except for the cost of shipping, of course! I am very interested in getting one. This is my regular email address: j.hanson32@yahoo.com
If you don't mind, please send picture to this email address. Thanks for the note.
derekhopkins
i have a PTO. You take the back plate off and it bolts in. Unfortunately, I am in Austrlia so not much good to you. I could send a photo if that would help.
everett048
Orange Level Joined: 12 Sep 2009 Location: uk Points: 617 |
same difference
chevytaHOE5674
Orange Level Joined: 21 Apr 2010 Location: DA UP, Mi Points: 260 |
That is a belt pully... |
everett048
There is a p t o on ebay not sure what Allis it fits but is n o s ??? 6 bolt fixing item no, 320638370626 |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41229 |
They are driven from a extension on the main-shaft of trany. Seen them in the manual but never on machine. Would be similar to cable drum drive used on HD6
Then with counterweights on 5 there would be no place of PTO
Edited by Coke-in-MN - 03 Jan 2011 at 1:33pm |
JHanson907
Looking for a bolt on PTO unit for my HD5. My AC HD5 manual shows these were available once upon a time. Has anyone seen one and/or know where I can get one?
