WABCO air compressor
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Topic: WABCO air compressor
    Posted: 05 Dec 2010 at 5:49am
Just got a WABCO air compressor. The motor in it looks like a D15. Anyone know anything about these. Model D226 (not motor) and 170 on the sheet metal.
"Burgie"
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 6:34am
Burgie: may have been a Westinghouse Air Brake unit. Can you post a picture of the Engine, so we can provide some insight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 7:25am
I think I did see Westinghouse on the tag. I will see what I can do about the pictures. Thanks
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 7:48am
WABCO , Westinghouse Air Brake Company, mfg of air brke components for rail and other air brake uses.
 Also did some hydraulic pumps .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 8:36am
After looking again I think it is a D17 motor. Behind the carb. it is stamped 17-82354-(?).
"Burgie"
armandjones82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote armandjones82 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 1:41am
Why won't you try to have a different air compressor for that one. Brands such as extreme outback products and the like would be a good thing to have in order to get the desired performance of your vehicle on that one. Hoping that all things would be good and better in the long run with the changes that you can make here.
Edited by armandjones82 - 18 Feb 2011 at 7:18pm
