CA Pickup Plow "Special Bolt" Meaning?
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Pickup Plow "Special Bolt" Meaning?
    Posted: Yesterday at 10:25am
What does the "special" refer to relative to the bolts used for the pickup plow?  Those I checked were fine thread.  Were these hardened beyond 4140?
1952 CA13092
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:18pm
sometimes allis used a plow bolt with a head shape that was unique to them. you can't find them anymore but with a welder and a die grinder you can get close enough
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:45pm
I only found 1 like that.  I found a "thumb screw" head bolt the right thread size and ground it to match.  The target bolt was basically a 3/4" round head with two opposite side flats.  I ground it to fit the slot in the plowshare and the bracket it mounts to.  Most of the other "special" bolts look like standard hex head bolts.  The only thing special about the ones I checked were that they were fine thread.  But that doesn't seem like a reason to use the term "special".
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:09pm
I believe the bolts you’re talking about are the frame bolts right.
They were some type of a shear bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:58pm
Two bolts below were 3/4 hex head bolts both fine threaded and labeled "special".  Would those be "shear" bolts?  Or would they be higher strength bolts?  The second one is the upper bolt of the U bracket.  I used grade 8.  I don't think it matters much at this point, was just curious.
CA Pickup Plow
#52? Plow
Edited by dfwallis - Yesterday at 6:09pm
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:26pm
The original part numbers for those were
321893 then the numerical book says use 916290 which are grade 5. 3/4” x 3-1/2”
321896 numerical book says to use 916292 which are grade 5. 3/4” x 4-1/4”
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:34pm
Hmm, grade 5 is roughly equivalent to 4140 which most everything else was, I thought.
Interesting comparison:
Edited by dfwallis - Yesterday at 6:48pm
1952 CA13092
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 8 minutes ago at 6:41am
Could it be a shoulder bolt? I've seen that in manuals too. Had that sort of stuff apart but been a long time ago and can't remember.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 6 minutes ago at 10:43am
The two bolts referenced were normal hex bolts (I'm reasonably sure the bolts I removed were original), only they were fine thread.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 41 minutes ago at 11:08am
I think my conclusion is that "special" just means any characteristic that is different from a standard hex head coarse thread (4140?) bolt.
1952 CA13092
wjohn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 29 minutes ago at 2:20pm
In general "special" could mean any deviation from whatever hardware standard (i.e. ISO etc. documentation) "typical" bolts come from. Could be as simple as the threads being a different pitch, a different hex size for the head, a non-standard length of threads on the shaft, a specified length of chamfer on the end leading to the threads, etc. etc. or something really obvious like a weird shape, totally different head type, or different material.
All "special" really tells you is that technically there is at minimum one small thing that doesn't line with the standard. Sometimes you can get away with an off-the-shelf bolt built per whatever standard, and sometimes you can't, but the manufacturer (AC in this case) typically had some reason for choosing that special bolt in the first place. It could just be something that made it easier to assemble or it could be something that kept it from failing in the field.
