Hay Wagon Progress |
NCAllisnut
Silver Level Joined: 11 Sep 2009 Location: Shelby NC Points: 365 |
Posted: 13 Nov 2010 at 8:55pm |
I finally got some time this afternoon to work on getting my wagon running gear apart. The previous owner had welded the fron to the back with a short section of pipe. They did a very thorough job of welding it. I went through several cutting disks and grinding disks. They even welded the outer tube to the inner pipe through a bolt hole. THat was fun to drill out.
I found a layer of orange under the gray and gunk. Any idea what brand this is?
I pulled the front wheels off to check the hunds. The first one came off full of bearing rollers, the second had water in it. I think I'll be buying four set of bearings, four seals, and a can or two of grease. It had a combination of Timiken, KOYO, and NTN bearings and races.
As advertised -
Today -
DanWi
Orange Level Access Joined: 18 Sep 2009 Location: wttn Points: 1709 |
Looks like a kory wagon.
Andrew(southernIL)
Orange Level Joined: 12 Sep 2009 Location: Metropolis, IL Points: 1086 |
Looks like the gears under a gravity wagon of ours and we were told they were Kory gears.
If fishing is a sport your looking at an athlete
NCAllisnut
Thanks for the info guys!
Eric[IL]
Orange Level Joined: 14 Sep 2009 Location: Illinois Points: 485 |
You may want to take your scrap steel from the tank frame and fabricate 4 bolster mounts from it that can be bolted into the 3 holes as seen on your wheel frames? |
NCAllisnut
That or some 3x3 angle iron I have in the metal pile.
Adam
ChuckLuedtkeSEWI
Orange Level Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Adam, sorry I didn't send you those pictures of my pivot on my running gear yet, but here they are. The tube has a slot cut into it, and the bolt has a square washer cut to match, so that the rear tube can pivot 15-20 degrees in each direction. Might not be the best design but gives you some ideas. |
NCAllisnut
Thanks Chuck - I'll have to figure something like that out.
Adam
