17D starter
Elvin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elvin Quote  Post ReplyReply Direct Link To This Post Topic: 17D starter
    Posted: 15 May 2025 at 6:39pm
Dr Allis ? Does someone make a Gear Reduction Starter for a D17 Diesel ? Can you remove a canister oil filter base and mount a Spin-On base ? Thanks, Elvin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 7:35pm
Oil filter base shouldn't be an issue. A newer gear reduction starter?? I have no idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 9:10pm
ebay.... ???
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 6:40pm
NEW IMI HIGH PERFORMANCE STARTER FITS ALLIS CHALMERS D SERIES 262 58-62 APS3882
$ 211.86 $ 423.72
Replaces Part Numbers & Specifications
ALLTECH: 104-3882 1043882
AMERICAN POWER SYSTEMS: APS3882
DELCO: 1113082
ITEM DESCRIPTION: STARTER
UNIT TYPE: DELCO
TYPE: OSGR
VOLTAGE: 12
ROTATION: CLOCKWISE
TEETH: 10
POWER: 2.5KW / 3.35HP
GEAR OD: 1.587IN / 40.3MM
MOUNTING EAR 1: 11.9MM UNTHREADED
MOUNTING EAR 2: 11.9MM UNTHREADED
MOUNTING EAR 3: 11.9MM UNTHREADED
Product Notice
As a parts distributor we mostly sell aftermarket parts (any OEM parts would be noted as such). Aftermarket parts are not sourced from the original vehicle or equipment manufacturer, but are designed to function the same as - if not better than - the original. All parts sold are new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 7:06pm
I have a D17D, spins over quickly. The key is good grounds and heavy battery cables. 2/0 welding cable with crimp connectors works best with the correct + and - terminals. They are a different size and it makes a world of difference. Not only on a diesel but gas as well. My WD suffered from a slow roll over until I changed all that out. Just started it today after winter hibernation and she spun over quickly and fired right up. 6V battery and didn’t even trickle charge it. I’m telling ya, it makes a world of difference.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 8:21am
Get the old starter rebuilt and it will be as good as new
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 12:09pm
I've used those newer style starters on my Olivers,they'll turn the motor faster than the originals and seem to need less battery power.
