WD45 Bogs Down When Hot |
Bill Long
Orange Level Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 03 Nov 2010 at 8:17am |
You can try the condenser first. That is the cheapest fix but normally it is the coil.
Let us know how it goes.
Good Luck!
Bill Long
TedBuiskerN.IL.
Orange Level Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
I had that problem with an RC. Turned out to be a large build up of rust, scale, sludge, etc. around the rear of the back sleeve, so it wasn't cooling and would seize the piston. It was the original cast iron piston, so the clearances were pretty tight.
dannyraddatz
Orange Level Joined: 12 Sep 2009 Location: Plainfield, Ill Points: 848 |
Did you find the problem?
Danny Raddatz
jyanna
Bronze Level Joined: 31 Oct 2010 Location: Michigan Points: 26 |
Thanks so much for all your suggestions!
DonBC
Orange Level Access Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 901 |
I would check the coil first and see if it is hot after the engine begins to bog down.
Orange Level Access Joined: 12 Sep 2009 Points: 19596 |
If tappets have been adjusted too tight, they will do that. Adjust to .015" COLD intake and exhaust........don't go thru that .010" when hot B.S. ...do them all cold at .015" and KNOW they aren't too tight.
kb
Bronze Level Joined: 12 Oct 2010 Location: PA Points: 8 |
Our WD45 was doing that same exact thing this spring. The coil was breaking down and it was fairly easy to figure out as you couldn't touch it hot.
dannyraddatz
I may be out there on this one but I had an old jeep that lost power. The valves had got out of adjustment and would loose power when it warmed up.
Danny Raddatz
Gatz in NE
Orange Level Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1034 |
Coil ok ?
Check points gap too.
jyanna
My WD45 starts and runs fine until it warms up. Then it bogs down and has no power. Just redid the carb and new plugs. There is coolant in the radiator. Guage shows temp OK. Water pump? Any ideas would be appreciated.
