Plow Sizing |
Author | ||
Travis2766
Silver Level Joined: 26 Aug 2015 Location: Amherst, Wi Points: 389 |
Posted: 23 Apr 2024 at 6:14am |
I am in the market for a bigger plow since I sold my 3 bottom. How many bottoms can I go comfortably with behind my 190XT diesel? I have very light sandy soil, I pull a 16’ field cultivator with an 18’ cart drag behind the 190 in my soil. I know the old saying of 20hp per bottom but I’d prefer to not pull the tractor too hard. Seems I can find 5 bottoms fairly cheap compared to 4 bottoms in my area. I think I could probably pull 6 bottoms but it’s going to harder on the tractor that I would like and I’m guessing I’d have traction issues. I don’t plow much, maybe 5 acres per year.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
Sponsored Links | ||
Orange Level Access Joined: 12 Sep 2009 Points: 19584 |
5 x 16's extremely common on a 190XT and 200 tractor.
Trinity45
Orange Level Access Joined: 17 Mar 2014 Location: Kentucky Points: 1596 |
The guy down the road pulls 5 -`6's with his and seems to walk away with it. I know I pull 4-16's with my 185 with very little problems.
TramwayGuy
Orange Level Access Joined: 19 Jan 2010 Location: Northern NY Points: 11241 |
I worked on a farm in Wisconsin in the ‘70s and the owner pulled 6-16’s with an on-land hitch and duals on his 190 XT. I think he had it ‘turned up’ a little, and was heavily weighted.
I think the 5-16s would be a good choice, and you don’t need an on-land hitch. Edited by TramwayGuy - 23 Apr 2024 at 1:04pm |
By my "old school" plow size formula (43 PTO HP will pull a 43 inch cut plow) The 94 HP mighty 190XT would pull 6 x 16's for 96 inches of cut. But at that time in history, farmers were wanting to plow a little deeper, so 5 x 16 was 80 inches of cut at a deeper plowing depth. A comparison of 6 x 16's x 5 inches deep would be the same as 5 x 16's at 6 inches deep for soil moved.
Edited by DrAllis - 23 Apr 2024 at 1:51pm |
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4415 |
I had a set of 5 bottom (semi-mount) and Dad had a set of 4 bottom mounted (both AC) plows. In our heavy clay sod, my 7000 did a lot better with the 4 bottoms than it did with the 5 bottoms.
Soil type makes a huge difference when it comes to pulling plows.
Brian F(IL)
Orange Level Access Joined: 14 Sep 2009 Location: Paxton, IL Points: 2691 |
Most of the One-Ninety XT's that were sold out of my dad's dealership were sold with 5-16" plows. Some may have been 4-16's if the farmer had mostly black gumbo. I never remember one being sold with a six bottom plow. Only D-21's and Two-Twenty's had 6 bottoms sold with them.
Orangeade
Bronze Level Joined: 09 Jun 2019 Location: NC Wis Points: 7 |
5-16 would be fine. But I wonder, since you say 5 acres to plow, does it really matter 4 or 5 bottom? You'll be done in 30 minutes.
Travis2766
I have a lot of rocks, I definitely have to go slow. Still going to take a few hours!
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3208 |
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2215 |
doin good to pull 3 bottoms here with my 190xtd! I got hard ground! lol!
WF owner
Sam thing here. Some of the ground in our area is heavy clay and hasn't been plowed in my memory. It takes power and weight to pull a plow in that.
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4430 |
X2 |
housemover
Bronze Level Joined: 01 May 2012 Location: Belleville, Ks Points: 102 |
Travis, Standard rule of thumb for engine life is, drop RPM's 10% increase engine life 30% or more! Same thing can be said for loads requiring heavy torque and also applies to transmission wear etc. The job of a dealership is to sell and/or promote. All older experienced farmers would drop 1 bottom in plow size change (or cut lathe with from say 16" to 14") because very few soil types are perfect. If you like your tractor and want to not pull the guts out of it all day long. In heavy soil or rocky ground 4 16" or 18 " bottoms are plenty. Decide what your ground speed is that feels comfortable in the seat & chose the angle (& type) of moldboard that makes the soil roll and crumble (or cover) nicely. Maybe a rock picker should be in line for you if rocks are to bad because they are hard on colters & good colters are VERY IMPORTANT to get a good square land shear in heavy soils. Also a spring trip helps you keep from tearing up your 3-point and plow in heavy rock soil . Just Experience Talking, Housemover
