Honda CRV tire ? |
mdm1
Orange Level Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2599 |
Posted: 30 Jan 2024 at 1:07pm |
My wife drives a 2020 Honda Crv and it's time for new tires. Her driving is mainly intown with a couple of trips to Des Moines each year. Any suggestions?
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21565 |
Let her pick out the tires, pay for them and then you HIDE in your garage !
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 6697 |
We put a whole set on our CRV, early last summer. Went with Cooper, as they were made in USA. So far so good.
mdm1
She maintains her own vehicle and the funds come from our joint account. And I don't have a garage, she does. I had Cooper on a truck once and found they would hydroplane a lot. I know a lot of people like them though. Maybe just my truck. It came with Bridgestone and only got 30,000 miles on them.
Dennis J OPKs
Silver Level Joined: 12 Sep 2009 Location: Overland Park, Points: 386 |
Check out Yokohama. In spite of the name, they do have 2 plants in the U. S. I'm sure opinions vary but I've heard some good things about them.
DanWi
Orange Level Access Joined: 18 Sep 2009 Location: wttn Points: 1707 |
Just put Hancook's on my wife's Grand Am. It has had Good years, BF Goodrich , and Coopers on it. So far like the Hancook's.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78031 |
I have Hancooks on the CAR and Yokos on the Truck... Like the way they handle... Wife does a lot of "drive around town" 90% of the time with front wheel drive FLEX... YEP.. those two tires wore out at 30K miles... Its the TYPE of driving, not the tire.
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1224 |
I have been using Toyo for a few years and am happy with them. Don't get the cheapest ones going as some want to do these days. Spend some more money and get better quality. You won't regret. Rotate them and check air. Really pays off.
Have them on a Chrysler 300(several years now) and on 2024 GMC 2500 -winter tread on this one. But very few miles so far on this one. Edited by Ed (Ont) - 30 Jan 2024 at 6:13pm |
mdm1
Did put Yokohamas on my truck. So far so good! Will check out Hancook. She's looking at Goodyear.
Edited by mdm1 - 30 Jan 2024 at 6:15pm |
thendrix
Orange Level Joined: 04 Feb 2013 Location: Fairmount GA Points: 4740 |
Toyo is also made in the US. There's a plant about 15 miles from here. Never have tried them so I can't speak to how they drive and hold up though.
Lars(wi)
My wife’s CRV come think of it is not great in a heavy rain. We had the same issues years ago with Ford Taurus’ our 1998, and 1999 Taurus’s could go anywhere anytime, down pour, blizzard, just motoring down the road, but then we got a 2004, that thing would slip & slide if there was a forecast of precipitation. Did not matter what brands of tire we ran on that car over the years, factory specs called for too big of a tire for the weight of that car.
Edited by Lars(wi) - 30 Jan 2024 at 7:20pm |
bobkyllo
Orange Level Joined: 14 Sep 2009 Location: minnesota Points: 1514 |
Toyo Celsius has been a great seller for me. It's the best of both worlds. A winter tire designed to be left on year round.
Hankook is also a great brand. |
DaveKamp
I just put a set of Hankooks on my daughter's 2002 CR-V... it's a 'college car'. What you'll find, is that 4wd CR-V's consume tires rather swiftly... and it's how the driveline works: You have what is basically a front-wheel drive car, where the differential pinion has a secondary power take-off exiting the rear-facing end of the transaxle. There is a driveshaft extending from that power takeoff (a small U-joint) to an isolated support bearing in two places under the floor, to a differential in the rear. Just BEFORE the differential gear (but inside the diff center section) is a combination viscous coupling with a clutch pack. As you roll down the road, the front wheels and rear wheels are following the same track, thus, roll the same distance, and the rear differential pinion rotates in synch with the driveshaft from the front, so the viscous coupling has no effect. When you have a wheel slip up front, the driveshaft spins FASTER, thus, the viscous coupling now gets two different speeds... this causes coupling to apply pressure to the clutch pack, forcing the clutch plates together, thus causing power from the front transaxle to bear into the rear differential, and now you have tractive effort applied to the rear wheels. This works fairly well, but when you're rolling down the road and say... one tire is a couple pounds lower than it should be, it needs to rotate MORE (to accomodate it's smaller rolling diameter) the viscous coupling is now working out the difference in speed, and that means the front and rear tires are bearing against eachother on dry pavement. So the CR-V's fuel economy is down a bit, and tires wear out faster... So I wouldn't expect miracle tire life. I haven't seen any of ours (we have four CR-Vs) get more than about 22k on a set of tires... and since there's a mile of gravel 'tween the house and county blacktop, we usually don't get good tire life on ANYTHING to begin with.
only AC orange
Silver Level Access Joined: 06 Dec 2014 Location: Eastern Indiana Points: 406 |
Our 2017 CR-V had Hankook's on it and at about 30.,000, they developed a vibration (at all road speeds). I replaced them with Michelin's (yes, pricey) and traded @ 90,000 + and no disappointments! Our 2022 CR-V has Continental tires and like them - 38,000 on it and tires look like new.
jdeere562
Bronze Level Joined: 02 Oct 2023 Location: SW Iowa Points: 16 |
I got Michelin Cross Climate 2 and love them. Great in snow and rain, 3 peak rated, but costly.
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18727 |
Hey Mike, Depends on what you want to spend....
My thought are (in order) Michelins and Hankooks. Never heard of Toyo so I can't say, but definitely worth looking into. Does she care about ride? I keep ALL my tires at 4 lbs under max. I can't tell the difference between 34 and 40 lbs per tire ride dif. BUT, I do definitely tell the difference between the gas mileage. As far as wear, who can tell? I'd have to have the same tires on and drive exactly the same for 30k to know. I care more about mileage... |
mdm1
As of now she is looking at either Hancooks or Toyo.
Ed (Ont)
Well did you get a some new sneakers?
Edited by Ed (Ont) - 08 Feb 2024 at 7:53pm |
mdm1
Not yet we were hoping for a buy 3 get 1. But it doesn't look good. She's going to get the Toyos.
mdm1
Well my wife ordered the Toyos or Toby's as she calls them. Will be put on Tues. Thanks to all with suggestions.
Ed (Ont)
