Throttle linkage on D17 series 4
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Throttle linkage on D17 series 4
    Posted: 24 Oct 2010 at 7:40pm
Mc-Master Carr has them for like $4-$5.  Thanks for reminding me to put that on my next order.   Mine came apart on my Series III D17 a couple months ago and I did exactly what Matt MN did to patch mine back together.  He's a link to page at McMaster-Carr.  Mike
http://www.mcmaster.com/#ball-joints/=9f601a
Also reminds me I have to measure the ball joint ends on the steering drag link on my Allis 716H mower and get them too at Mc-Master Carr - same page.   It too came apart about the same time!
Edited by Skyhighballoon(MO) - 24 Oct 2010 at 7:43pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 5:36pm
I used a hammer and punch and pinched it together again. very easy to do.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 5:33pm
I got 2 of them a year ago from my AGCO dealer. $11.24 each. I thought that was a pretty good price.
ChuckLuedtkeSEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 4:38pm
Thanks Russ,  I used the number and it pulled it right up.   Now at least I can call and gasp when they tell me how much it will be!!   That is if it's still available.
Edited by ChuckLuedtkeSEWI - 24 Oct 2010 at 5:11pm
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 3:55pm
230339 would be a starting point...
The innovators offer what others will imitate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 3:50pm
I bought one from my AGCO dealer a couple years ago.  I'll look for a part number...
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 3:43pm
I had one of those on my Case 830 . I took it off and put it in a vice and used a small punch and hammer to close the hole around the ball.  My D17 is held togather with baleing wire also, has been good for years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 2:58pm
Here is a picture:
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2010 at 2:52pm
On the throttle linkage on my D17 series 4, right underneath the gas tank, there is a small rod that comes forward that on the end has an end with a ball joint on it, that snaps into a socket piece for the next series of the linkage.   this ball and socket piece is worn out and the ball falls out of the socket.   I looked page by page under AGCO's online parts catalog, and could not find it listed on there.   I was wondering if anyone knew if these two parts were available yet, or where I could go to find them.   I would like to get this fixed before winter as the baler wire that was holding it doesn't let it pivot good, and I don't want it to be broken in the middle of winter as I use this tractor to clean the driveway.   I will try to take a picture of the two pieces and post on here.
