D 15 gas engine |
ACinSC
Orange Level Joined: 16 Dec 2015 Location: South Carolina Points: 2575 |
Posted: 16 Oct 2023 at 2:39pm |
After working mine hard it's now blowing watery looking oil out of the breather/oil fill cap . It's down at the 'farm' now . Soon as I get it back to my shop I need to figure out what's going on . Probably check the compression first. The rad might be a little low , but sure not much . May need to 'rent' auto zones rad pressure tester again I guess ? Used the tester about a year ago when I had the head rebuilt . Always something , it seems . Thanks !
Edited by ACinSC - 17 Oct 2023 at 10:09am |
Straanger
Bronze Level Joined: 10 Dec 2019 Location: Michigan Points: 24 |
If you haven’t it for a year, and then worked it hard, you might want to let it sit for a day, then crack the oil drain plug and see what you get. Water, antifreeze, or just oil. A lot of condensation happens in a year. If all that comes out is oil, then you worked the condensation out.
ACinSC
Oh I've run it a good bit since the head was rebuilt. My concern is all this oil blowing out. Thanks
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77889 |
If the crankcase is PRESSURIZED then you blow oil out the vents.. If you see WATER in the blow by.......... its normally a head gasket problem..
ACinSC
Kinda what I was wondering Steve. Thanks
RedHeeler79
Bronze Level Joined: 09 Sep 2023 Location: NE Kansas Points: 78 |
I had a WD45 years ago that would put coolant into the oil and the top end got that watery sludge forming in it. Turned out that the block was cracked in between the cylinder sleeves at the lower bores. Just another possibility and place to look. Of course the pan has to come off to verify this problem or when the seals on the sleeves have failed. Hopefully your D15 doesn’t have this same issue…
ACinSC
I've had a little condensation ever since I put the rebuilt head on. Can't figure why it blowing oil out? Something must have changed to cause that ? Thanks guys
Orange Level Access Joined: 12 Sep 2009 Points: 19560 |
This is the same scenario you had a year ago, right ?? And you pulled the head off without dropping the pan first to try and determine where the coolant was getting into the motor oil ?? Check the radiator. If it is low on coolant, I think it's going into the motor oil.
Edited by DrAllis - 17 Oct 2023 at 3:38am |
ACinSC
Different deal, this time it's blowing a lot of oil out of the breather. Oil looks a little watery to me
Also I've worked this tractor since the head rebuild. Did have some condensation inside the valve cover but none in the pan. Oil blowing out just started after working the tractor hard recently. Thanks |
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4413 |
If oil is "blowing out", somewhere you are getting pressure (compression) in the oiling system, either past the piston rings, a hole in a piston or sleeve, head gasket or a crack, either in the head or block. Did the tractor ever overheat?
The big question is......radiator low ?? or NOT ???
ACinSC
Thanks(1)
Gauge did get up to about 200 degrees before I cleaned the weeds off the radiator. Don't think that qualifies as overheating though? Radiator might be a little bit low. Didn't have a flashlight or a step stool to get a good look at the 'farm' Thanks
If an engine is low enough on coolant, the temp gauge doesn't necessarily read correctly because there may not be coolant touching the sensor. So, for example if your engine is one gallon low on coolant, the gauge may say 200 degrees but it may well be hotter than that.
ACinSC
It wasn't near that low . I checked it with a screwdriver , just couldn't see where the level was . Once I get it back here in my shop I'll start troubleshooting . Just wonder what would cause the oil to blow out like it does ? Thanks !
modirt
Orange Level Access Joined: 18 Jul 2018 Location: Missouri Points: 6645 |
What head gasket was used on rebuild? When we did the D15 / 160 engine the first time, we used the head gasket that came in Reliance overhaul kit, and it leaked right off. The test was to fill the radiator to cover the head gasket, then let it sit overnight (or a few days) to see if water started dripping out the oil drain plug. It did with Reliance gasket. The vintage real deal replacement held. Seems the same test would be in order for you now. Would reveal a failed head gasket or cracked block? All you are out is some time and an oil change.
ACinSC
Don't recall head gasket brand . Did hold 10 psi all night after install . Thanks Modirt
Phil48ACWC
Silver Level Joined: 17 Jan 2013 Location: Vermont Points: 278 |
Did the oil level go up? If coolant level went down and oil level went up, it's obvious coolant is getting into the oil. Gotta fix it.
ACinSC
No, oil level was low. It'll take a while to get it in my shop and I'll post what I find. Thanks
