912 allis does wheelys |
Fed
Bronze Level Joined: 29 Oct 2020 Location: Pa Points: 2 |
Posted: 19 Jul 2023 at 1:38pm |
When I leave the clutch out, it doesn't catch gradually, it grabs all at once and you do a wheely. I have to use the tractor in low range and have the throttle very low to keep from lifting the front tires off the ground. I've replaced belts, greased everything, and made sure all the pulleys are moving free. I checked all the fluids in the transmission and rear end. I can't figure out why it's grabbing. Anyone with a suggestion?
farmtoybuilder
Orange Level Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1453 |
Are all the belt guides in place and adjusted right? And then need correct width & length belt. Should be able to release clutch without jerking! Need a manual to check all the hi low range adjustments.
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8155 |
Lift the seat up with it in neutral and operate the clutch and watch how the idler releases. Maybe you can see where it’s acting up.
