Allis B hot start problem |
Author | ||
LittleB
Bronze Level Joined: 18 Aug 2020 Location: Ontario Ca. Points: 21 |
Posted: 02 Jun 2023 at 1:59pm |
I have what has become a recurring problem with my B. While it starts and runs like a top, if I stop and shut it off once it warms up I can't depend on it restarting. I have replaced the magneto coil and condenser which is the suspect for this problem. Incidently I replaced the condenser again about 3 months ago due to to this problem. I would like to try a reliable condenser that doesn't come through the Pacific Rim. Any suggestions on the best brand and part# would be appreciated for a reliable condenser.
Joe
Sponsored Links | ||
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77748 |
I think your going to find that 99% of the condensers are made in China... Best just to keep a couple spares around.. I dont know anyone that advertises "usa made" on the condensers..
LittleB
I guess I'll just stock up on condensers then. Are there any good brands from China.
Joe
you might feel better if you bought from a Reputable supplier instead of just some random guy on e-bay.... But thats not guarantee you get a better condenser... But you HOPE the Vendor has done his homework and MIGHT be buying a better product.
Steve at B&B is our local "electrical guy" when it comes to distributors / mags/ generators and starters.. Edited by steve(ill) - 03 Jun 2023 at 12:58pm |
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2204 |
Its ALL chimna crap now days and about 2/3'rds of them are bad out of the box, so you be the judge!
mdm1
Orange Level Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2592 |
Blue Streak from Napa comes highly recommended. I have not used them but will when I need new parts. I bought from a reputable dealer and had some problems with ignition parts. Talked to him and he said it is a problem. He replaced my parts.
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50530 |
Put a pertronix unit on it, and never have to change P&C again...
And, unless kalifornia is a foreign country (?) they're 'Merican!
LittleB
I would jump at the opportunity to install a pertronix, but my B fires off a magneto.
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1905 |
Old timers will tell you that is not uncommon. There is a valve on the manifold that is used to help that problem. The solution was to leave the engine running with the clutch locked open. I put electric start on all my tractors and power units.
http://lonsallischalmers.com
John426
Silver Level Joined: 14 Aug 2012 Location: France Points: 271 |
Where is this valve on the manifold? I don't have that.
john... 99% of the manifolds do not have the vavle.. Older manifolds had a pipe plug where a valve could be installed.. Newer manifolds have a flat boss where the hole use to be, but most are no longer drilled and tapped.
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4412 |
For anything electrical, the only place I go is www.brillman.com . When I do get something with magneto problems I have them TOTALLY rebuild it. Often there are more things wrong that are age related than just a condenser. Age can weaken the magnets and doing a shade tree rebuild won't cure that. Coils also suffer from old age and heat kills them. You can keep doing it yourself and have endless problems, or have it professionally done right and tested with a guarantee and it will outlast you.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11550 |
We're a Standard Blue Streak dealer. Been a dealer since 68'. So far, we haven't had any problems that I know of with SMP. Even though their made in Mexico, I'm thinkin' it gotta' be better than China. So far, we're been doin' alright with our tune up parts.... Steve@B&B
LittleB
I will denifatly going the Blue Streak route. The suggested reliability far outwieghs my concerns in the China product.
Now concerning the post regarding the valve in the manifold, I am baffled in how this aided the hot restarts. |
mdm1
https://www.allischalmers.com/forum/vaccuum-thing-on-a-b-manifold_topic40213.html Check this link out. May or may not answer your question. I have one B with the valve another without. The engine with it is from a power unit and is electric start. Wish it was on the crank start.
LittleB
Okay, I understand now the makeup of this valve and it's purpose. I even experienced milking the herd during power failures using the vacuum valve on our Fordson Major in my younger days. I just didn't know its dual purpose.
KMAG
Orange Level Access Joined: 26 May 2020 Location: Elizabethtown, Points: 656 |
The Why.
The ethanol fuel is boiling in the carb when sitting causing an overly rich condition. The intake manifold valve being opened for hot starts helps the engine start easier/less cranking. |
Greg (Hillsboro, OH)
Orange Level Joined: 11 Sep 2009 Location: Hillsboro, OH Points: 1161 |
Our B was always hard to start once it quit after it had been working a while. We always commented that the B was telling us it was time to take a break and go sit under a tree a while and have some cold lemonade.
John426
later this valve was removed. The hot start problem is gone. Probably no more vapor lock.
What improvements have been implemented to solve the problem? Carburetor? Manifold? Engine?
What changed is a NEW coil, NEW condenser, NEW point..... Something was getting HOT and breaking down electrically... The VALVE was not the fix... it was there for other reason to produce a vacuum source. .... i have several B tractors and they all start when HOT... Just have to have good electrical system... and they are all electric start.. start on 1-2 revolutions of the motor.
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 609 |
Please tell me more, I have a Model C-type power unit (currently on a 60 combine) that is hand-crank only. Is there an electric start option? My Model C tractor doesn't like to start hot unless the throttle is nearly closed, one notch above minimum idle and it starts instantly. Edited by Les Kerf - 05 Jun 2023 at 6:36pm |
Lon(MN)
Thanks(1)
mdm1
Thanks(1)
Les Kerf
Thank you for the link and the wonderful pictures on your website I was unable to see the actual starter locations even when zoomed in on the photos; was there a different bell housing/PTO adapter for these units? Mine doesn't seem to have any place to install a starter. |
Lon(MN)
Thanks(1)
A different Bell housing is needed to allow a starter.
Thanks(1)
